Installation & Licensing
Cross Vertical product licensing
2 REPLIES 2
slakose
200 Views, 2 Replies
I have several floating seats of Civil and Map that are not being used.  I need addational seats of AutoCAD, is it possible to draw from that seat pool when I run out of AutoCAD licenses?
Steven LaKose
2 REPLIES 2
TravisNave
in reply to: slakose
If it is network licensing, the cascading should work automagically.  What versions and what licensing scheme are you using?
Autodesk Forums:
slakose
in reply to: TravisNave
They are all 2011 licenses.
Seems due to that they are seperate packages, (AutoCAD, Civil and Map) I don’t think they will automatically cascade.
It's been bumped up to the Autodesk support team and I forwarded them some licensing info.
I'm hopedful that they may be able to adjust the license file.
Steve
Administrator Productivity
