Installation & Licensing
Creative Suite Ultimate 2013, All things failed to install
5 REPLIES 5
331 Views, 5 Replies
So, I went to boot up 3ds max a few days ago to attempt to do some modeling, however, it was saying that it had an Error 20, apparently my Antivirus deleted FLEXnet. So I uninstalled all Autodesk software, and went to reinstall it, in hopes it would reinstate FLEXnet.
Half way through the install, The installer crashed.
Now NOTHING will install, and seeing the money that was paid for these products, I would very much like to actually USE the products.
Thank you in advance.
5 REPLIES 5
Soyoung.H
Please check the links talking about how to clean uninstall Autodesk' product.
Recommended uninstall and reinstall procedures
http://usa.autodesk.com/adsk/servlet/ps/dl/item?id=10243968&linkID=9240617&siteID=123112
If you can't remove then completely, you can use Microsoft Fix it.
How to manually uninstall the product using Microsoft Fix it
http://usa.autodesk.com/adsk/servlet/ps/dl/item?id=21891972&linkID=9240617&siteID=123112
When you try to reinstallation, please keep in mind this
- If you have full acess/privilege as an administrator
- You can avoid Anti-virus program disrupted in safe mode
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2893432&linkID=9240617
Soyoung.H
I did a full clean uninstall, it's a matter of, it gets to a certain point, whilst running in admin mode, then just stops, it stopped at that point for a good 4 hours today, refused to install. I should note, I am running Windows 7, 64 bit.
Nothing installs at All, 3ds Max, Maya, or anything as part of the Suite.
Soyoung.H
Clean uninstallation is just a prep.
Try install in safe mode. It will prevent from obstructions.
Soyoung.H
I attempted to install in Safe Mode, however it told me all had failed, A little Red X next to each program was displayed on a sort of splash screen. It yeiled far less results than a normal mode attempt did.
Soyoung.H
Did you follow the guideline from above link??
Clean installation on Windows® XP or Vista
4. Click the Services tab and select the Windows Installer check box.
Soyoung.H
Administrator Productivity
