Installation & Licensing
created install package but short cut is no longer .exe
28 REPLIES 28
Message 1 of 29
806 Views, 28 Replies
created the install package with the wizard, tested the install just fine. Now my .exe file that has the codes is now showing up as a short cut only. I've attached what I see in explorer and the script when I open it with notepad ++
Please help!! Smiley Sad
28 REPLIES 28
Message 21 of 29
TravisNave
Does it work if you disable your anti-virus?  I have seen similar issues with Avast and Symantec.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Message 22 of 29
in reply to: TravisNave
wasn't the anti-virus, after the deployment was created I changed the folders around and the code did not match. The error made us believe otherwise 🙂
but now I have one last item, after my deployment gets modified I am unable to not install the AutoCAD 360 part of the application. I modified the deployment of course and un-checked that option but it still gets installed.
Message 23 of 29
TravisNave
Yeah, lots of complains on that one too.  You can modify the setup.ini to remove the installation for this.  I don't have the reference for this at the moment, but it is searchable.
Autodesk Forums:
Message 24 of 29
would this be the product section in the .ini file?
#============================= Autodesk Cloud Sync ============================= EXE_PARAM= PATCHES=
[ADSYNC] PLATFORM=NATIVE PRODUCT_NAME=Autodesk Cloud sync EXE_PATH=%platform%\Components\Cloudsync\AdSync.msi EXE_PARAM=ADLANGUAGE=%selectedlang% LOG=%tmp%\CloudsyncInstall.log IGNORE_FAILURE=YES ACTION=INSTALL
Message 25 of 29
TravisNave
Bingo!
Autodesk Forums:
Message 26 of 29
will this line just needed to be changed only?
ACTION=INSTALL
if so what should it be? just tried notinstall but still installed
Message 27 of 29
TravisNave
You need to delete all references to it everywhere in the file.
Autodesk Forums:
Message 28 of 29
where would the actual product key be in the deployment housed?
Message 29 of 29
TravisNave
For 360, just do a search for ADSYNC.  That should get it.
Autodesk Forums:
Administrator Productivity
