Installation & Licensing
TravisNave
Message 21 of 29 (99 Views)
Re: created install package but short cut is no longer .exe
08-27-2013 09:44 AM in reply to: nsaska
Does it work if you disable your anti-virus?  I have seen similar issues with Avast and Symantec.
nsaska
Message 22 of 29 (86 Views)
08-29-2013 06:03 AM in reply to: TravisNave
wasn't the anti-virus, after the deployment was created I changed the folders around and the code did not match. The error made us believe otherwise :-)
but now I have one last item, after my deployment gets modified I am unable to not install the AutoCAD 360 part of the application. I modified the deployment of course and un-checked that option but it still gets installed.
TravisNave
Message 23 of 29 (83 Views)
08-29-2013 07:49 AM in reply to: nsaska
Yeah, lots of complains on that one too.  You can modify the setup.ini to remove the installation for this.  I don't have the reference for this at the moment, but it is searchable.
nsaska
Message 24 of 29 (76 Views)
08-29-2013 08:12 AM in reply to: TravisNave
would this be the product section in the .ini file?
#============================= Autodesk Cloud Sync ============================= EXE_PARAM= PATCHES=
[ADSYNC] PLATFORM=NATIVE PRODUCT_NAME=Autodesk Cloud sync EXE_PATH=%platform%\Components\Cloudsync\AdSync.msi EXE_PARAM=ADLANGUAGE=%selectedlang% LOG=%tmp%\CloudsyncInstall.log IGNORE_FAILURE=YES ACTION=INSTALL
TravisNave
Message 25 of 29 (73 Views)
08-29-2013 08:47 AM in reply to: nsaska
nsaska
Message 26 of 29 (68 Views)
08-29-2013 09:13 AM in reply to: TravisNave
will this line just needed to be changed only?
ACTION=INSTALL
if so what should it be? just tried notinstall but still installed
TravisNave
Message 27 of 29 (63 Views)
08-29-2013 10:18 AM in reply to: nsaska
You need to delete all references to it everywhere in the file.
nsaska
Message 28 of 29 (60 Views)
08-29-2013 12:25 PM in reply to: nsaska
where would the actual product key be in the deployment housed?
TravisNave
Message 29 of 29 (53 Views)
08-29-2013 01:19 PM in reply to: nsaska
For 360, just do a search for ADSYNC.  That should get it.
