Installation & Licensing
created install package but short cut is no longer .exe
28 REPLIES 28
Message 1 of 29
nsaska
802 Views, 28 Replies
created the install package with the wizard, tested the install just fine. Now my .exe file that has the codes is now showing up as a short cut only. I've attached what I see in explorer and the script when I open it with notepad ++
Please help!! Smiley Sad
28 REPLIES 28
Message 21 of 29
TravisNave
in reply to: nsaska
Does it work if you disable your anti-virus?  I have seen similar issues with Avast and Symantec.
Autodesk Forums:
Message 22 of 29
nsaska
in reply to: TravisNave
wasn't the anti-virus, after the deployment was created I changed the folders around and the code did not match. The error made us believe otherwise 🙂
but now I have one last item, after my deployment gets modified I am unable to not install the AutoCAD 360 part of the application. I modified the deployment of course and un-checked that option but it still gets installed.
Message 23 of 29
TravisNave
in reply to: nsaska
Yeah, lots of complains on that one too.  You can modify the setup.ini to remove the installation for this.  I don't have the reference for this at the moment, but it is searchable.
Autodesk Forums:
Message 24 of 29
nsaska
would this be the product section in the .ini file?
#============================= Autodesk Cloud Sync ============================= EXE_PARAM= PATCHES=
[ADSYNC] PLATFORM=NATIVE PRODUCT_NAME=Autodesk Cloud sync EXE_PATH=%platform%\Components\Cloudsync\AdSync.msi EXE_PARAM=ADLANGUAGE=%selectedlang% LOG=%tmp%\CloudsyncInstall.log IGNORE_FAILURE=YES ACTION=INSTALL
Message 25 of 29
TravisNave
in reply to: nsaska
Bingo!
Autodesk Forums:
Message 26 of 29
nsaska
will this line just needed to be changed only?
ACTION=INSTALL
if so what should it be? just tried notinstall but still installed
Message 27 of 29
TravisNave
in reply to: nsaska
You need to delete all references to it everywhere in the file.
Autodesk Forums:
Message 28 of 29
nsaska
in reply to: nsaska
where would the actual product key be in the deployment housed?
Message 29 of 29
TravisNave
in reply to: nsaska
For 360, just do a search for ADSYNC.  That should get it.
Autodesk Forums:
Administrator Productivity
