created the install package with the wizard, tested the install just fine. Now my .exe file that has the codes is now showing up as a short cut only. I've attached what I see in explorer and the script when I open it with notepad ++
Please help!!
Welcome to the community.
Nothing is attached.
Is this a deployment wizard?
yes, I created a deployment using the contents of the CD installation files
Is there a reason you needed to create a deployment instead of just running the setup?
we're running SCCM 2012 and install most software via un-attended install using SCCM
I see. If you just run the shortcut, does it launch the installer? That's the purpose of creating the deployment.
Did you make your deployment correctly?
You need to make a shared folder on the server with full write access to everyone and configure the deployment to run via that UNC path. I recommend \\servername\share, with full control to the everyone built-in user account. I also recommend that you uncheck silent mode if you are having issues.
Don't use drive letters in your deployment or forget to set sharing *and* folder permissions on the location of the files.
Additionally, I do not recommend including a service pack with the deployment, initially. Get everything working and tested first.
yes I did. After I completed it I was able to successfully install it and uninstall it from my machine. Then someone walked into my office started talking to me and my mouse was over the files and I left clicked and some how that file became a short cut and ever since then I can't get it to start. I even deleted it and re-created the deployment. I'm starting to think it's something with my machine so I'm copying over the contents from the CD to a another machine and will re-create the deployment there also to eliminate my machine as the problem
That's probably a good idea. However, keep in mind that a deployment creates a shortcut and you launch it by traversing to the UNC path and running it that way. It may just as well work from another workstation.
when you view your install.exe file in notepad or notepad ++ what do you see on your end? also want to eliminate that the original CD contents was corrupted by me
That is irrelevant as there is no reason to launch your installation in notepad.
my new code that is now not working,
:: Set script parent directory: SET _ScriptDir=%~dp0 SET _ScriptDir=%_ScriptDir:~0,-1%
:: Run OS architecture check: IF NOT DEFINED PROGRAMFILES(X86) ( ECHO. ECHO ERROR: 32-Bit Windows Operating Systems are unsupported! Exiting... REM Delay for processing: PING 127.0.0.1 -n 3 > NUL EXIT )
:: Display status message: ECHO. ECHO Installing Autodesk AutoCAD 2014...
:: Run install commands: START "Install" /WAIT "%_ScriptDir%\SRC\x64\Setup.exe" /qb /I "%_ScriptDir%\SRC\x64\AutoCAD_2014.ini" /language en-us
:: Display completion notice: ECHO. ECHO Done!
:: Delay for processing: PING 127.0.0.1 -n 3 > NUL
:: Uncomment to view script results: :: ECHO. :: PAUSE EXIT
This is usually an issue with an anti-virus program, like Trend Micro.
this is the log from another installation attempt after I cleaned out my temp folder but the AV application is turned on by GPO so I'll need to see about getting around it
log:
2013/8/27:10:37:17 nsaska LAP5CB2442H61 === Setup started on LAP5CB2442H61 by nsaska === 2013/8/27:10:37:17 nsaska LAP5CB2442H61 Path_Length: 152 2013/8/27:10:37:17 nsaska LAP5CB2442H61 Current Directory C:\Users\nsaska\Desktop\AutoCAD_2014\SRC\x64 2013/8/27:10:37:17 nsaska LAP5CB2442H61 Launch 2013/8/27:10:37:17 nsaska LAP5CB2442H61 CommandLine /MD "C:\Users\nsaska\Desktop\AutoCAD_2014\SRC\x64\AutoCAD_2014.ini" /ML /language en-us 2013/8/27:10:37:17 nsaska LAP5CB2442H61 Path_Length: 152 2013/8/27:10:37:17 nsaska LAP5CB2442H61 Current Directory C:\Users\nsaska\AppData\Local\Temp\_AI5EB5.tmp 2013/8/27:10:37:59 nsaska LAP5CB2442H61 === Setup ended ===
2013/8/27:10:37:18 nsaska LAP5CB2442H61 === Setup started on LAP5CB2442H61 by nsaska === 2013/8/27:10:37:18 nsaska LAP5CB2442H61 Path_Length: 152 2013/8/27:10:37:18 nsaska LAP5CB2442H61 Current Directory C:\Users\nsaska\AppData\Local\Temp\_AI5EB5.tmp 2013/8/27:10:37:18 nsaska LAP5CB2442H61 Launch 2013/8/27:10:37:18 nsaska LAP5CB2442H61 The system cannot open the device or file specified. 2013/8/27:10:37:22 nsaska LAP5CB2442H61 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\nsaska\AppData\Local\Temp\_AI5EB5.tmp\Setup\AcSetup.dll 2013/8/27:10:37:22 nsaska LAP5CB2442H61 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink= 2013/8/27:10:38:00 nsaska LAP5CB2442H61 === Setup ended ===
same results with following the article you sent me here - http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=21889889&linkID=9243099&CMP=OTC-RSS...
just looked into this article - http://esupport.trendmicro.com/solution/en-US/1096841.aspx but we are not even running TrendMicro on our machines
