Installation & Licensing
created install package but short cut is no longer .exe
28 REPLIES 28
Message 1 of 29
826 Views, 28 Replies
created the install package with the wizard, tested the install just fine. Now my .exe file that has the codes is now showing up as a short cut only. I've attached what I see in explorer and the script when I open it with notepad ++
Please help!! Smiley Sad
28 REPLIES 28
Message 2 of 29
TravisNave
Welcome to the community.
Nothing is attached.
Autodesk Forums:
Message 3 of 29
in reply to: TravisNave
been up since 1AM with the baby, screen shots are now attached
Message 4 of 29
TravisNave
Is this a deployment wizard?
Autodesk Forums:
Message 5 of 29
yes, I created a deployment using the contents of the CD installation files
Message 6 of 29
TravisNave
Is there a reason you needed to create a deployment instead of just running the setup?
Autodesk Forums:
Message 7 of 29
we're running SCCM 2012 and install most software via un-attended install using SCCM
Message 8 of 29
TravisNave
I see.  If you just run the shortcut, does it launch the installer?  That's the purpose of creating the deployment.
Autodesk Forums:
Message 9 of 29
the short cut launches it starts initialzing but never goes anywhere
Message 10 of 29
TravisNave
Did you make your deployment correctly?
You need to make a shared folder on the server with full write access to everyone and configure the deployment to run via that UNC path.  I recommend \\servername\share, with full control to the everyone built-in user account.  I also recommend that you uncheck silent mode if you are having issues.
Don't use drive letters in your deployment or forget to set sharing *and* folder permissions on the location of the files.
Additionally, I do not recommend including a service pack with the deployment, initially.  Get everything working and tested first.
Autodesk Forums:
Message 11 of 29
yes I did. After I completed it I was able to successfully install it and uninstall it from my machine. Then someone walked into my office started talking to me and my mouse was over the files and I left clicked and some how that file became a short cut and ever since then I can't get it to start. I even deleted it and re-created the deployment. I'm starting to think it's something with my machine so I'm copying over the contents from the CD to a another machine and will re-create the deployment there also to eliminate my machine as the problem
Message 12 of 29
TravisNave
That's probably a good idea.  However, keep in mind that a deployment creates a shortcut and you launch it by traversing to the UNC path and running it that way.  It may just as well work from another workstation.
Autodesk Forums:
Message 13 of 29
when you view your install.exe file in notepad or notepad ++ what do you see on your end? also want to eliminate that the original CD contents was corrupted by me
Message 14 of 29
TravisNave
That is irrelevant as there is no reason to launch your installation in notepad.
Autodesk Forums:
Message 15 of 29
my new code that is now not working,
:: Set script parent directory: SET _ScriptDir=%~dp0 SET _ScriptDir=%_ScriptDir:~0,-1%
:: Run OS architecture check: IF NOT DEFINED PROGRAMFILES(X86) (  ECHO.  ECHO ERROR: 32-Bit Windows Operating Systems are unsupported! Exiting...  REM Delay for processing:  PING 127.0.0.1 -n 3 > NUL  EXIT )
:: Display status message: ECHO. ECHO Installing Autodesk AutoCAD 2014...
:: Run install commands: START "Install" /WAIT "%_ScriptDir%\SRC\x64\Setup.exe" /qb /I "%_ScriptDir%\SRC\x64\AutoCAD_2014.ini" /language en-us
:: Display completion notice: ECHO. ECHO Done!
:: Delay for processing: PING 127.0.0.1 -n 3 > NUL
:: Uncomment to view script results: :: ECHO. :: PAUSE EXIT
Message 16 of 29
Message 17 of 29
TravisNave
This is usually an issue with an anti-virus program, like Trend Micro.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=21889889&linkID=9243099&CMP=OTC-RSS...
Autodesk Forums:
Message 18 of 29
this is the log from another installation attempt after I cleaned out my temp folder but the AV application is turned on by GPO so I'll need to see about getting around it
log:
2013/8/27:10:37:17 nsaska LAP5CB2442H61 === Setup started on LAP5CB2442H61 by nsaska === 2013/8/27:10:37:17 nsaska LAP5CB2442H61 Path_Length: 152 2013/8/27:10:37:17 nsaska LAP5CB2442H61 Current Directory C:\Users\nsaska\Desktop\AutoCAD_2014\SRC\x64 2013/8/27:10:37:17 nsaska LAP5CB2442H61 Launch 2013/8/27:10:37:17 nsaska LAP5CB2442H61 CommandLine /MD "C:\Users\nsaska\Desktop\AutoCAD_2014\SRC\x64\AutoCAD_2014.ini" /ML /language en-us   2013/8/27:10:37:17 nsaska LAP5CB2442H61 Path_Length: 152 2013/8/27:10:37:17 nsaska LAP5CB2442H61 Current Directory C:\Users\nsaska\AppData\Local\Temp\_AI5EB5.tmp 2013/8/27:10:37:59 nsaska LAP5CB2442H61 === Setup ended ===
2013/8/27:10:37:18 nsaska LAP5CB2442H61 === Setup started on LAP5CB2442H61 by nsaska === 2013/8/27:10:37:18 nsaska LAP5CB2442H61 Path_Length: 152 2013/8/27:10:37:18 nsaska LAP5CB2442H61 Current Directory C:\Users\nsaska\AppData\Local\Temp\_AI5EB5.tmp 2013/8/27:10:37:18 nsaska LAP5CB2442H61 Launch 2013/8/27:10:37:18 nsaska LAP5CB2442H61 The system cannot open the device or file specified. 2013/8/27:10:37:22 nsaska LAP5CB2442H61 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\nsaska\AppData\Local\Temp\_AI5EB5.tmp\Setup\AcSetup.dll 2013/8/27:10:37:22 nsaska LAP5CB2442H61 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink= 2013/8/27:10:38:00 nsaska LAP5CB2442H61 === Setup ended ===
Message 19 of 29
Message 20 of 29
just looked into this article - http://esupport.trendmicro.com/solution/en-US/1096841.aspx  but we are not even running TrendMicro on our machines
Administrator Productivity
