I am trying to create a silent installation for CFD2012. This silent installation will be shared for clients users to do the installation.
There is a document of how to create deployment : http://wikihelp.autodesk.com/Product_Design_Suite/enu/2012/Help/2000-Installa0/0148-Network_148/0149...
This seems help to me. But I just cant find how to reach the steps of "Configure <name> page".
Can anyone help me?
Solved by david.lau. Go to Solution.
We had to go old school on this one.
“C:\Autodesk\Simulation CFD 2012\setup.exe” /t /qb /c CFD: INSTALLDIR="C:\Program Files\Autodesk\Simulation CFD 2012" ACADSTANDALONENETWORKTYPE=3 ACADSERVERPATH=”LICENSE_SERVERname 000000000000” ACADSERIALPREFIX=### ACADSERIALNUMBER=######## ACADLICENSETYPE="Network License" ACADLICENSESERVERTYPE="Single Server License" REBOOT=ReallySuppress
It is also based on the old Maya and MotionBuilder Silent installs in 2010.
http://mayastation.typepad.com/maya-station/2009/08/maya-2010-deployment.html
http://usa.autodesk.com/getdoc/id=TS14262142
Thanks for the command. I tried it out, saw the problem as the attached picture.
Any clue? Thanks.
Since there is no deplyement icon as what I expected origionally, I tried this command and the installation script based on this article:
my network license server is specified as : 27002@xxx.domain. So I have question regarding to the script of RunSingleLicenseServerInstall :
strADSKServerPath = "myFlexNetServer"
' HOSTID or MAC address
strADSKServerHOSTID = "000000000000"
' Consolidate the two values
strADSKServerPath = strADSKServerPath & " " & strADSKServerHOSTID
How can I specify this license server in this syntax?
Thanks again.
This is the command I am using. I changed the setup.exe folder according to my situation.:
“C:\Autodesk\Simulation_CFD_2012_MultiLingual_Win_32bit\setup.exe” /t /qb /c CFD: INSTALLDIR="C:\Program Files\Autodesk\Simulation CFD 2012" ACADSTANDALONENETWORKTYPE=3 ACADSERVERPATH=”portno@domain.com” ACADSERIALPREFIX=xxx ACADSERIALNUMBER=xxxxxxxx ACADLICENSETYPE="Network License" ACADLICENSESERVERTYPE="Single Server License" REBOOT=ReallySuppress
Thanks!
The issue with the command line is the type of double quote used. Ones marked in blue are good, red ones confuse the cmd.exe. Please retype double quotes using the keyboard.
THANKS to my co-worker Hashim Mundol on this one.
