Installation & Licensing
Message 1 of 9
igroup.kskoog
1042 Views, 8 Replies
Create Deployment
Our server is outdated and it may be awhile before we update it. Want to create a deployment for Building Design Suite 2014. What would be the best way to install the suite. Can I go "install on this computer" for all users until we get an upgraded server or can I create a deployment onto an external hard drive and use that to install for the other users?
Kory Skoog
CADD Technician
8 REPLIES 8
Message 2 of 9
TravisNave
in reply to: igroup.kskoog
As for the deployment server location, it doesn't really matter how amazing the server is, so long as it has a decent network card and enough storage space.
Otherwise, you can install direct from download as network version.  You don't technically need a deployment image if you choose not to.  I don't recommend creating a deployment to a removable drive though.  That one is a nightmare.
Autodesk Forums:
Message 3 of 9
Thanks for the reply. I tried to create a deployment on our server and I got and error message saying Building Design Suite 2014 is not supported by the operating system (Windows 2000 Server). So I could not go any further.
Kory Skoog
CADD Technician
Message 4 of 9
TravisNave
This is normal. Create the deployment from your workstation and target the
deployment location to the UNC share on the server. Done.
Autodesk Forums:
Message 5 of 9
igroup.kskoog
in reply to: TravisNave
Ok I started setp. Now I get a message saying it cannot find "MediumImageLibrary2014.msi" file then it stops.
Kory Skoog
CADD Technician
Message 6 of 9
TravisNave
You need to disable your anti-virus.
Autodesk Forums:
Message 7 of 9
When I try to choose a location for the deployment none of my drives show. Only "network" is an option. Thru network I cannot see any drives. Our server is drive I:\ which is not listed on the "network" nor is any other drive. Is 2014 only "network" based and no longer able to install on computers? Or is there a setting I am missing? Frustration is kicking in. Never had this much trouble before.
Kory Skoog
CADD Technician
Message 8 of 9
TravisNave
Create a share writable to everyone then use a UNC path as your target.
Autodesk Forums:
Message 9 of 9
emily.xu
Do not use mapped drive. Use UNC path for your deployment location, like \\computername\sharedfolder.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Emily Xu
Product Support
Administrator Productivity
