When i start installing SetupDWGTrueView2011_32bit_fra.exe, i get the installing starting and finishing on a CRC error :
See details below:
Unexpected end of archive
I have only 7zip 4.57 or Winzip 9.0 SR1, not Winrar (can't install it; no license). So i don't know if the problem could come from it or not. Or if your install CRC is corrupted. When i check the zip with 7zip, it says the message below (image enclosed).
Started to install this 2011 version when previous install DWG TrueView 2009 started to fail launching.
Sorry for the late answer but download again DWGTrueView2011 and disable your anti-virus during the install.
Best regards.
I'll hijack the OP's thread if he's done with it.
Having similar issues but with 3D Studio Max Design.
CRC fails on a number of cab files, no antivirus running. I've tried the automatic downloads, as well as the "if you're having trouble downloading use your browser" option, but give the same result.
CRC failed in support\dotnetfx\dotnetfx35.exe
CRC failed in support\ADSKMaterials\ILM\Common~1.cab
CRC failed in support\Partners\Composite\x64\runtime.cab
CRC failed in support\Partners\CityScape\CityScape1_8_0.msi
CRC failed in support\components\Components_3dsMaxDesign2011_32-bit.msi
CRC failed in support\components\Components_3dsMaxDesign2011_64-bit.msi
CRC failed in support\Partners\Composite\x64\Composite 2011.msi
CRC failed in support\Partners\Composite\Composite 2011.msi
CRC failed in SetupRes\eval.msi
CRC failed in support\SAMreport-Lite\Java 2 Runtime Environment, SE v1.4.2_04.msi
Am I missing something?
Perhaps a problemwith your RAM.
Try to copy your download on another PC and test to install.
You can also phone your reseller or Autodesk to have a DVD.
Extracting msi\WindowsInstaller-KB893803-v2-x86.exeExtracting msi\WindowsServer2003-KB942288-v4-ia64.exeCRC failed in msi\WindowsServer2003-KB942288-v4-ia64.exe
CRC error appears at the end of the install bar it seems.
Why are there Windows Server 2003 updates necessary on a Windows XP Pro SP2?
it is not necessary but it's part of the archive of Dwgtrueview2011.
Then we know if it's the archive or your pc the problem.
Having similiar issues... Tried downloading 2012, 2011, and 2010 revisions of Inventor along with 2012 3DS Max Design all of which give me the silimiar error messages. I don't have another computer to download to and am not the greatest at figuring all this stuff out. My system is as follows:
Operating system is Windows 7 premium 64 bit
AMD A4-3305M APU with Radeon HD Graphics (2 CPUs)= 1.9 GHz
Ram 8GB
AMD Radeon HD 6480G Graphics card
Also I had disabled the antivirus thru-out the whole process. Is my system the problem or did I miss something...
I am using WINRAR install
Yeah I have been trying to get someone to help me from the contact us on the main site for over two month. I have gone though this forum with no luck. If there is a link that can help me please let me know. The contact us e-mail referred me here with no real explaination of what could be wrong PLEASE HELP I am exetremly frustated at the complete lack of help and the length of time I have gone without even a clue as to whats wrong. I have watched all the install videos and believe that I have done everything correctly. Even an explaination of what a CRC error is would be appreicated. Oh due to the lack of response I will now on will be leaving messages daily until I get some infromation.
Dear 08956599,
I see that you have two educational products with us. Please send me a Private Message (click on my bielskj profile name, then "Send this user a private message") with your serial number so I can research your issue.
Dear08956599,
I have sent you a private message with a case number. Please let me know if I can help you with anything else.
Hi, I have the same problem, got Windows 7 x64, tried to install inventor x64 versions 2012 and 2013, both didnt succed, giving me the same error as above "CRC failed in x64....." for more than one file. What can I do to fix it? Please help me, I switched my antivir and firewalls off during download and instalation.
I'm attaching .txt file with the results of instalation, hoping it will help you solve my problem.
Regards.
Problems downloading the Autodesk software and/or CRC errors may be avoided by using another web browser, or using the alternate browser download method.
For more detailed information on this process, please see the following blog post tip here:
http://upandready.typepad.com/up_and_ready/2011/08/downloading-software-browser-download-vs-download...
