Extracting x64\max\Autodesk_3ds_Max_2012_FCS.cab
Extracting x86\max\Autodesk_3ds_Max_2012_FCS.cab
Extracting x86\Components\backburner\backburner.cab
Extracting 3rdParty\DirectX\BDANT.cab
Extracting 3rdParty\DirectX\BDAXP.cab
Extracting x86\max\CER_Glob.cab
Extracting x64\max\CER_Glob.cab
Extracting x86\max\CER_Loc.cab
Extracting x64\max\CER_Loc.cab
Extracting x86\max\CommCenter.cab
Extracting x64\max\CommCenter.cab
Extracting Content\ADSKMaterials\2012\ILM\Common~1.cab
CRC failed in Content\ADSKMaterials\2012\ILM\Common~1.cab
Unexpected end of archive
I've redownloaded many times on difrent browsers and have my secruity disabled... what is up with this?
Solved by sigvek. Go to Solution.
Problems downloading the Autodesk software and/or CRC errors may be avoided by using another web browser, or using the alternate browser download method.
For more detailed information on this process, please see the following blog post tip here:
http://upandready.typepad.com/up_and_ready/2011/08/downloading-software-browser-download-vs-download...
That typically works. You can also try downloading from another computer. If your anti-virus is running (especially if it scans inside of compressed archives) then you might try downloading with that disabled.
On a side-note, have you downloaded all of the parts to this program? Unexpected End of Archive errors can generally mean either the download itself wasn't fully completed or you are missing an addtional *.rar file in the set.
I have tried numerous times this weekend. Downloaded with two Macs and four PCs. I have tried from home, work and a friend. I have tried with OS X Lion, Win Vista, Win 7 and Win 8. Different browsers like IE, Firefox(Aurora), Chrome and Safari.
I have tried to just run the self extractor and manually extract it using different applications like 7-Zip, WinRaR, Unarchiver.
I get the same result every time.
My guess is that Autodesk is using a reverse proxy of some kind, that cache the file we download. That file or the cache is corrupted.
Finally I got it
What I did:
Omg i am getting so frusterated! there is only browser download and when i right click it it doesnt say copy link url i need help!
