Installation & Licensing
Could not launch AutoCAD Architecture 2013 ( on FDSU 2013 )
7 REPLIES 7
Message 1 of 8
haisin_rusli
1099 Views, 7 Replies
I have Installed FDSU 2013 Network version on my notebook, all software works well except AutoCAD Arhitecture 2013.
There was a message " A valid license could not be obtained by the network license manager ". I did not know why this was happened because I could launch AutoCAD, AutoCAD Mechanical, Inventor without problems.
I have gone to Control Panel--> Program and features--> repair AutoCAD Architecture --> but did not work,
then reinstall  AutoCAD Architecture --> but did not work,
Did it because of License problem? How to Fix it ?
Best Regards,
Haisin Rusli
Inventor Professional 2013 SP1.1
Windows 7 Pro 64-bit, SP1
HP EliteBook 8460w; 8 GB RAM; i7 - 2.0 GHz; AMD Firepro M3900 -1 GB
Haisin Rusli
Sales Engineer - PT Wahana Cipta Sinatria
Silver Partner - Autodesk Partner Manufacturing
Surabaya
7 REPLIES 7
Message 2 of 8
DarrenP
in reply to: haisin_rusli
this is a license issue
check the status of flex lm on the status inquiry tab
and see if there are license available
DarrenP
Message 3 of 8
haisin_rusli
Hi Darren,
I have checked the status of flex lm on the status inquiry tab, but it shown no specific AutoCAD Architecture License ( maybe for version 2012 and 2013, the License was different ).
I checked on www.licenseparser.com it shown as attached file.
We have 6 License of FDSU and  6  License of PDSU, I thought that only PDSU that active.
How to fix this issue ? Should I re-activeate the FDSU License again?
Best Regards,
Haisin Rusli
Haisin Rusli
Surabaya
Message 4 of 8
DarrenP
does navisworks manage 2013 launch? or is it only autocad architecture from the factory suite
DarrenP
Message 5 of 8
DarrenP
in reply to: DarrenP
do the factory design utilities work inside the inventor product?
DarrenP
Message 6 of 8
haisin_rusli
HI Darren,
Yes you're right, Navisworks Manage 2013 and Factory Design Utilities inside Inventor could not launch either.
So it must be License's issue, what should I do ?
Best Regards,
Haisin Rusli
Haisin Rusli
Surabaya
Message 7 of 8
DarrenP
there is something wrong with the license file
try redoing it
DarrenP
Message 8 of 8
haisin_rusli
Hi Darren,
It's solved now, thank you for the support !
Because there was a conflict between FDSU 2013 and PDSU 2013 Licenses ( and some other Autodesk products ), so I have to re-activate FDSU and PDSU on the same day.
Best Regards,
Haisin Rusli
Haisin Rusli
Surabaya
Administrator Productivity
