The install of Revit 2013 was interrupted. Not sure why or how to fix it, but hopefully someone can explain what the errors mean in the attached log.
It is aborting on the download
Install Autodesk® Revit® 2013 Language Pack Failed Download Failed, Installation aborted, Result=1603
I would recommend that you try downloading your product using the virtual assistant by following the directions here:
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-...
