Installation & Licensing
*Noonan, Michael P.
Message 1 of 5 (81 Views)
Converting Full Install to Client Install
81 Views, 4 Replies
05-18-2000 06:44 AM
We currently are running standalone installations of AutoCAD 14.
We are converting to a license manager. Is there a file that I can
modify, delete or overwrite that will make the full install point to the
ADLM
instead??
Is there a manual that can be purchased/ downloaded for ADLM???
Thanks for your help.
Mike Noonan
*Martin, Jason
Message 2 of 5 (81 Views)
Re: Converting Full Install to Client Install
05-18-2000 08:00 AM in reply to: *Noonan, Michael P.
There is no "supported" way to convert a stand alone install into an ADLM
aware install. There are some rumors that some people have made it work
without re-installing but I've not seen any detail about how, and Autodesk
won't support it anyway.
I've not seen any manual specifically for ADLM but it's really pretty
simple. Your installation guide should have a chapter on Install in and
Using Autocad on a network that will walk you thru the basic steps.
Basic things that you need to do are:
1. Install the ADLM on a machine and get the auth code from Autodesk
2. Build a Client Deployment (Follow the bouncing ball mostly, you'll
need some space on a server that everyone can get to for the "image")
3. Copy all of your customized files from the local machine to another
folder
4. Uninstall the local copies of Autocad
5. Install the client deployment to the local workstations
6. Copy your customized files back over the newly installed files (back
them up first)
hth
jason martin
frankfurt-short-bruza
"Michael P. Noonan" wrote in message
news:ef09000.-1@WebX.SaUCah8kaAW...
> ADLM
> instead??
> Mike Noonan
*milana, jerry
Message 3 of 5 (81 Views)
Re:
05-18-2000 09:25 AM in reply to: *Noonan, Michael P.
Good Advice, Jason!
Michael, for additional documentation on AdLM you may want to visit
http://www3.autodesk.com/adsk/support/troubleshoot/0,,123882--125452-20022_2
1843,00.html
and
http://www3.autodesk.com/adsk/support/troubleshoot/0,,123882--125452-20021_2
1843,00.html
The first URL is the AutoCAD 2000 Network Tech doc index, the second is the
Release 14 Network index. License management issues for 2000 and Release 14
are essentially the same.
Jerry Milana,
Autodesk Product Support
"Jason Martin" wrote in message
news:ef09000.0@WebX.SaUCah8kaAW...
> folder
> them up first)
> hth
> jason martin
> > ADLM
> > instead??
> > Mike Noonan
*Noonan, Michael P.
Message 4 of 5 (81 Views)
Re:
05-22-2000 05:05 AM in reply to: *Noonan, Michael P.
I think Autodesk has updated their site, neither of these links work.
jerry milana wrote in message ...
>Good Advice, Jason!
2
>1843,00.html
>and
2
>1843,00.html
14
>Jerry Milana,
>> folder
(back
>> them up first)
>> hth
>> jason martin
the
>> > ADLM
>> > instead??
>> > Mike Noonan
*Hurley, Shaan
Message 5 of 5 (81 Views)
Re:
05-22-2000 06:15 AM in reply to: *Noonan, Michael P.
Michael,
The links work fine. Due to the long length of the URL make sure you copy
the entire URL. The long URLs wrap and if you do not specifically copy all
the URL it will be a dead end. You can also use the search and search on the
word ADLM in the Knowledge Base.
AutoCAD® 2000 Knowledge Base Index-Network (Copy the entire URL)
1843,00.html
AutoCAD® Release 14 Knowledge Base Index-Network (Copy the entire URL)
1843,00.html
Cheers,
-Shaan
news:ef09000.2@WebX.SaUCah8kaAW...
> >Good Advice, Jason!
> 2
> >1843,00.html
> >and
> 2
> >1843,00.html
the
> 14
> >Jerry Milana,
ADLM
work
> Autodesk
and
you'll
another
> >> folder
> (back
> >> them up first)
> >> hth
> >> jason martin
> the
> >> > ADLM
> >> > instead??
> >> > Mike Noonan
