Can I convert my AutoDesk AutoCAD Mac license to a PC? If not, can I upgrade to a PC 2014 version and with my Mac license number?
Solved by DarrenP. Go to Solution.
read through this: http://forums.autodesk.com/t5/Installation-Licensing/AutoCAD-2014-Windows-Mac-cross-license/td-p/391...
DarrenP
you didn't read the whole thread
Confirming that you can in fact use your AutoCAD 2014 serial number and product key to Activate AutoCAD for Mac 2014.
I also wanted to point out that per the Autodesk Product Activation FAQ, most license types (excluding educational) allow the software to be installed and activated on 2 separate machines, as long as you are the sole user and the 2 aren't used concurrently. AKA you could in theory have AutoCAD installed on both your Mac and PC at the same time.
Philip Schmelzer
DarrenP
I was finally able to locate my download center but only AutoCAD for Mac was available for download. How do I access the Windows version?
you could go this route but this currently down right now
You can access most current + previous supported version Browser Download links (including the Design & Creation Suites) through Matt, Autodesks Virtual Assistant. http://autodesk.creativevirtual15.com/autodesk/bot.html?isJSEnabled=1&businessArea=Root.Front%20Desk...
>download links
DarrenP
