Installation & Licensing
configuração do lmtools
3 REPLIES 3
737 Views, 3 Replies
estou com problema em configurar meu lmtools apresenta a seguinte mensagem O DAEMON DO FORNECEDOR DESEJADO É BAIXO,VERIFIQUE O ARQUIVO LOG IMGRD OU TENTAR IMREREAD.meu servidor esta ok mas  adskflex está com erro.
Aguem pode me ajudar,
agradeço desde já.
joel
joel@escolaprotec.com.br
3 REPLIES 3
TravisNave
Bemvindo,
Seu adskflex.exe fornecedor daemon está falhando. Isto poderia ser devido a um certo número de razões.
1. Seu arquivo de licença não tem o nome ou endereço MAC correto.
2. Você tem o Windows Server 2008 ou mais recente e tem um problema com a versão mais recente do LMTOOLS. Eu recomendo a versão 11.7.
http://forums.autodesk.com/t5/Installation-Licensing/Autodesk-Network-License-Manager-2014/m-p/38199...
3. Você está enfrentando um problema de rede IPv6. Ver o meu link sobre isso.
http://forums.autodesk.com/t5/Installation-Licensing/Network-License-Error-1-5-15-and-IPv6/td-p/2982...
Boa Sorte!
Autodesk Forums:
dembkod
joel,
Hello. LMTOOLS errors like this usually indicate a conflict on the server. Either there are other services trying to use the same licensing ports, or the license file is coded for a different MAC address.
If this file came from another machine, it is will not work on your new machine. The entire file is coded for a specific MAC, and if you open the file and look at the top row, you should see the MAC it is trying to use. Check the MAC in LMTOOLS- is it the same MAC? Does LMTOOLS list multiple MAC addresses? If so, get a new lic file configured for the other MAC address and see if that file will start.
If you have other services running in LMTOOLS for other products, they could be crowding the ports. In this case, you could open the Lic file and add a port to the end of the top line to restrict to a specific port. Our products use 27000-27009. I would try 27005 and see if you can start the service.
The top of a Lic file restricted to a port would resemble this:
SERVER COM5CB31805RQ 3ZZ9f4324zb0 27005
USE_SERVER
VENDOR adskflex port=2080
Thank you for taking part in our community!
David Dembkoski
olá boa noite.
Estou ainda com problemas ao configurar o LMTOOLS, mas com sua ajuda acho que descobri aonde está o problema.
Você me mandou no meu e-mail está mensagem abaixo e realmente é isso que esta acontecendo, por isso não consigo configurar meu servidor.
"Se este arquivo veio de outra máquina, é não irá funcionar em sua nova máquina. O arquivo inteiro é codificado para um MAC específico, e se você abrir o arquivo e olhar para o topo de linha, você deve ver o MAC ele está tentando usar. Verifique o MAC em LMTOOLS-é o mesmo MAC? O LMTOOLS lista vários endereços MAC? Se for assim, obter um novo arquivo lic configurado para o outro endereço MAC e ver se esse arquivo irá iniciar."
Não consigo gerar um novo arquivo lic no  https://registeronce.autodesk.com, apresenta o seguite erro.
Irei te mandar em anexo o erro ok.
Será que você pode me ajudar a liberação do registro de ativação para que eu possa gerar um novo lic para meu novo micro.
Já enviei uma solicitação de serviço ao cliente para a Autodesk informando sober o produto, mas não tive retorno.
Presciso que me ajude URGENTE.
Agradeço desde já pela competência de voçês.
Aguardo retorno...
Administrator Productivity
