Installation & Licensing
complex License file issues
8 REPLIES 8
Message 1 of 9
calvin.streeting
857 Views, 8 Replies
we have a complex lience file of
autocad (2008-2013)
3dsmax (2008-2011)
revit (2010-2013)
and all was working well until we added MEP to the mix.. now vanila revits nic the MEP lience. and if i reseve it for the MEP machines it reserves the 3dsmax + others as well..
do i need seperate servers, etc.. or can these liences be combined.. (with out the dark art of casscade)
Tags (2)
8 REPLIES 8
Message 2 of 9
Newer licenses with cascade will supersede older licenses.  To properly combine them, you will have to regenerate your older license files on the same date as the newer ones.  Otherwise, this will never work.  Subscription files will automatically supersede pre-existing older licenses.  Thus a 2013 license file will supersede any existing 2012, 2011, and 2010 file from the same package.  This is by design.  You cannot launch more than the number of seats you own total, regardless of release year.  If you have one seat of Revit, for example, you cannot simply launch five seats from 2008 to 2012.  You can only launch one.
Autodesk Forums:
Message 3 of 9
i know that 🙂
but for example i have 2 max license and buy a MEP building suite license (which includes a copy of max)... so that means 3 licenses... correct?
But if you open MEP on any machine it nabs the max license and no-one can open max on any other machine.. and thats not right?
Message 4 of 9
DarrenP
in reply to: calvin.streeting
is this 3ds max or 3ds max design?
it matters
DarrenP
Message 5 of 9
calvin.streeting
in reply to: DarrenP
max design.... why?
ps. sorry old school as started on 3dsmax for dos.. lol
Message 6 of 9
dgorsman
Better to think of that combination of licenses as "2 3DSMAX + 1 BDS".  Its easy to get into the habit of thinking "I have 3 MAX licenses and 1 MEP" and get frustrated trying to figure out why somebody can't get into MEP, or why only two people can run MAX.
Message 7 of 9
calvin.streeting
in reply to: dgorsman
ok..
please.... when i reserve the MEP it also reserves the max... so i can only open 1 copy..
i will get debug logs etc...
Message 8 of 9
ok here is the status from the server. and from this i can see one user has BDSP open and we should still have spare max liences but the machine reports -4.132.0 (no lience) but i wonder if its just i have no line for the 2 max 2011's
Users of 85787BDSPRM_F:  (Total of 1 license issued;  Total of 1 license in use)
  "85787BDSPRM_F" v1.000, vendor: adskflex
  floating license
    codrin.hiristea 2wzhp4j 2wzhp4j (v1.000) (BGFS1/27000 2314), start Thu 11/29 9:03
Users of 70100MAXDES_F:  (Total of 2 licenses issued;  Total of 0 licenses in use)
Users of 85503MAXDES_2011_0F:  (Total of 1 license issued;  Total of 0 licenses in use)
Status
Flexible License Manager status on Thu 11/29/2012 13:31
[Detecting lmgrd processes...]
License server status: 27000@BGFS1
    License file(s) on BGFS1: C:\Program Files\Autodesk Network License Manager\License\bgfs1.lic:
     BGFS1: license server UP (MASTER) v11.10
Vendor daemon status (on BGFS1):
  adskflex: UP v11.10
Feature usage info:
Users of 568003DSMAX_2008_0F:  (Total of 1 license issued;  Total of 0 licenses in use)
Users of 64300ACD_F:  (Total of 14 licenses issued;  Total of 4 licenses in use)
  "64300ACD_F" v1.000, vendor: adskflex
  floating license
    anjali.kale BXQWF5J BXQWF5J (v1.000) (BGFS1/27000 2905), start Thu 11/29 10:32
    mariola.viegas 9XQWF5J 9XQWF5J (v1.000) (BGFS1/27000 826), start Thu 11/29 8:36
    rumyana.apostolova 5XQWF5J 5XQWF5J (v1.000) (BGFS1/27000 2019), start Thu 11/29 8:16
    sean.hall 4XZH24J 4XZH24J (v1.000) (BGFS1/27000 508), start Thu 11/29 11:30
Users of 54600ACD_2008_0F:  (Total of 13 licenses issued;  Total of 4 licenses in use)
  "54600ACD_2008_0F" v1.000, vendor: adskflex
  floating license
    Aga.milanov JWGMN1J JWGMN1J (v1.000) (BGFS1/27000 2806), start Thu 11/29 8:05
    chrise cvzhp4j cvzhp4j (v1.000) (BGFS1/27000 1205), start Wed 11/28 10:44
    scott.tracey 3wzhp4j 3wzhp4j (v1.000) (BGFS1/27000 3103), start Thu 11/29 8:09
    stewartb FVZHP4J FVZHP4J (v1.000) (BGFS1/27000 3005), start Thu 11/29 11:17
Users of PLIST:  (Total of 1 license issued;  Total of 0 licenses in use)
Users of 54700REVITS_2008_0F:  (Total of 6 licenses issued;  Total of 0 licenses in use)
Users of 65900REVITS_F:  (Total of 7 licenses issued;  Total of 2 licenses in use)
  "65900REVITS_F" v1.000, vendor: adskflex
  floating license
    chrise cvzhp4j cvzhp4j (v1.000) (BGFS1/27000 721), start Wed 11/28 14:12
    rory.newell JVZHP4J JVZHP4J (v1.000) (BGFS1/27000 612), start Thu 11/29 7:41
  floating license
Users of 85946BDSPRM_2013_0F:  (Total of 1 license issued;  Total of 0 licenses in use)
Users of 85787BDSPRM_2012_0F:  (Total of 1 license issued;  Total of 0 licenses in use)
Users of 85837NAVSIM_2012_0F:  (Total of 1 license issued;  Total of 0 licenses in use)
Users of 85793REVSYP_2012_0F:  (Total of 1 license issued;  Total of 0 licenses in use)
Users of 85792REVSU_2012_0F:  (Total of 1 license issued;  Total of 0 licenses in use)
Users of 85536ACD_2011_0F:  (Total of 15 licenses issued;  Total of 0 licenses in use)
Users of 85652BDSPRM_2011_0F:  (Total of 1 license issued;  Total of 0 licenses in use)
Users of 85561ARCHDESK_2011_0F:  (Total of 1 license issued;  Total of 0 licenses in use)
Users of 85595STRDET_2011_0F:  (Total of 1 license issued;  Total of 0 licenses in use)
Users of 85562BLDSYS_2011_0F:  (Total of 1 license issued;  Total of 0 licenses in use)
Users of 85607SHOWCASE_2011_0F:  (Total of 1 license issued;  Total of 0 licenses in use)
Users of 85615ALSK_2011_0F:  (Total of 1 license issued;  Total of 0 licenses in use)
Users of 85543REVITST_2011_0F:  (Total of 1 license issued;  Total of 0 licenses in use)
Users of 85541RVTMPB_2011_0F:  (Total of 1 license issued;  Total of 0 licenses in use)
Users of 85614RVTMPJ_2011_0F:  (Total of 1 license issued;  Total of 0 licenses in use)
Users of 85601NAVSIM_2011_0F:  (Total of 1 license issued;  Total of 0 licenses in use)
Users of 85594REVSU_2011_0F:  (Total of 1 license issued;  Total of 0 licenses in use)
Users of 85624REVSYP_2011_0F:  (Total of 1 license issued;  Total of 0 licenses in use)
Users of 71200ACD_2010_0F:  (Total of 15 licenses issued;  Total of 2 licenses in use)
  "71200ACD_2010_0F" v1.000, vendor: adskflex
  floating license
    mariola.viegas 9XQWF5J 9XQWF5J (v1.0) (BGFS1/27000 1817), start Thu 11/29 8:36
    rumyana.apostolova 5XQWF5J 5XQWF5J (v1.0) (BGFS1/27000 2108), start Thu 11/29 8:16
Users of 82200STRDET_2010_0F:  (Total of 1 license issued;  Total of 0 licenses in use)
Users of 72200ARCHDESK_2010_0F:  (Total of 1 license issued;  Total of 0 licenses in use)
Users of 70000MAXDES_2010_0F:  (Total of 1 license issued;  Total of 0 licenses in use)
Users of 74100REVIT_2010_0F:  (Total of 1 license issued;  Total of 1 license in use)
  "74100REVIT_2010_0F" v1.000, vendor: adskflex
  floating license
    codrin.hiristea 2wzhp4j 2wzhp4j (v1.0) (BGFS1/27000 1413), start Thu 11/29 9:03
Users of 73800RVTMPJ_2010_0F:  (Total of 1 license issued;  Total of 0 licenses in use)
Users of 73000BLDSYS_2010_0F:  (Total of 1 license issued;  Total of 0 licenses in use)
Users of 82400RVTMPB_2010_0F:  (Total of 1 license issued;  Total of 0 licenses in use)
Users of 71500NAVSIM_2010_0F:  (Total of 1 license issued;  Total of 0 licenses in use)
Users of 74000REVSU_2010_0F:  (Total of 1 license issued;  Total of 0 licenses in use)
Users of 73100REVSYP_2010_0F:  (Total of 1 license issued;  Total of 0 licenses in use)
Users of 85954REVITS_2013_0F:  (Total of 7 licenses issued;  Total of 1 license in use)
  "85954REVITS_2013_0F" v1.000, vendor: adskflex
  floating license
    rory.newell JVZHP4J JVZHP4J (v1.0) (BGFS1/27000 3803), start Thu 11/29 7:41
Users of 85791REVITS_2012_0F:  (Total of 7 licenses issued;  Total of 0 licenses in use)
Users of 85623REVITS_2011_0F:  (Total of 7 licenses issued;  Total of 0 licenses in use)
Users of 74200REVITS_2010_0F:  (Total of 7 licenses issued;  Total of 1 license in use)
  "74200REVITS_2010_0F" v1.000, vendor: adskflex
  floating license
    chrise cvzhp4j cvzhp4j (v1.0) (BGFS1/27000 1509), start Wed 11/28 14:12
Users of 612003DSMAX_2009_0F:  (Total of 2 licenses issued;  Total of 0 licenses in use)
Users of 85871ACD_2013_0F:  (Total of 14 licenses issued;  Total of 2 licenses in use)
  "85871ACD_2013_0F" v1.000, vendor: adskflex
  floating license
    anjali.kale BXQWF5J BXQWF5J (v1.0) (BGFS1/27000 1014), start Thu 11/29 10:32
    sean.hall 4XZH24J 4XZH24J (v1.0) (BGFS1/27000 410), start Thu 11/29 11:30
Users of 85730ACD_2012_0F:  (Total of 14 licenses issued;  Total of 0 licenses in use)
Message 9 of 9
Yeah, I am not even seeing MAX 2011 in this status.
Autodesk Forums:
Administrator Productivity
