Installation & Licensing
Member
rjaynes
Message 1 of 7 (342 Views)
Comparison of network licensing types
342 Views, 6 Replies
10-19-2012 06:14 AM
I am trying to decide upon a Single Server or Distributed license server model.  My issue is that if I use the single server method I have to put in on a computer that can be left running at all times.  The drawback here is that the teachers who would be using the Audodesk software use laptops and if they are not present here on the network will they be able to run the software?
The opposite question is if I use the distributed license model and set each of their three laptops up as license servers, what happens to the clients in-building when those laptops are not present on the network?
Either method seems to have a drawback so I am looking for the pros and cons of each.
Thank you.
*Expert Elite*
TravisNave
Message 2 of 7 (334 Views)
Re: Comparison of network licensing types
10-19-2012 07:58 AM in reply to: rjaynes
I recommend the single license server.  When your instructors wish to take their laptops offline, they can first borrow their network license and it will work while away.  That will leave the existing license manager for others to access.  Furthermore, it will be easier if you ever set up VPN access to the license server while remote.
Travis Nave Send TravisNave a Private Message                       Need help in your post? Mention me with @TravisNave
Member
rjaynes
Message 3 of 7 (329 Views)
10-19-2012 08:31 AM in reply to: TravisNave
TravisNave,
Thank you for your response.  How do they "borrow" the network license when going off-site?  I am new to this software and have never used/installed it before.
*Expert Elite*
TravisNave
Message 4 of 7 (325 Views)
10-19-2012 08:41 AM in reply to: rjaynes
Borrowing is under the Tools menu or under Help > About > Product Information.  The user can simply borrow the license up to 6 months and go offsite.  It's very convenient.  :smileyhappy:
jtbworld
Message 5 of 7 (314 Views)
10-19-2012 05:52 PM in reply to: rjaynes
You might want to limit maximum borrowing time using the options file because if you don't and the laptop is stolen or the like the license will be unavailable for the rest of the borrowing time.
Jimmy Bergmark
JTB World - Software development and consulting
Specialities: AutoCAD, AutoCAD Architecture and Revit
http://www.jtbworld.com
JTB FlexReport - network license reports
http://www.jtbworld.com/jtbflexreport/index.htm
Member
rjaynes
Message 6 of 7 (277 Views)
10-22-2012 07:59 AM in reply to: jtbworld
I have a further question.  We deployed the software via network share and the "psexec" utility.  Apparently they all installed as "standalone" mode.  Is there a way I can mass-uninstall them and then re-deply from the NLM?
I know that is a loaded question however I would appreciate a stepped out process.
Thank you.
*Expert Elite*
TravisNave
Message 7 of 7 (269 Views)
10-22-2012 09:06 AM in reply to: rjaynes
Oops!  That's an unfortunate mistake.  You might try this on one of your machines to see if it works.  It might save you some uninstall/reinstall time.  It's hit or miss.  Some have had luck but I have not.
http://upandready.typepad.com/up_and_ready/2012/04/autocad-family-2013-hacking-the-registry-to-chang...
Announcements
Need installation help?
