Installation & Licensing
Member
danl337
Message 1 of 4 (4,180 Views)
Communication failure problem
4180 Views, 3 Replies
11-04-2012 05:10 PM
Hello
I'm trying to install autocad2013 on windows xp however when i go to run the program a communication failure box pops up. It says download and installation has been inturrupted by a lost connection between the autodesk website and this computer. I turned off my firewall but the problem still persists. Any suggestions?
Member
danl337
Message 2 of 4 (4,177 Views)
Re: Communication failure problem
11-04-2012 05:32 PM in reply to: danl337
and I have no option of saving the program to my computer, I can only run it on mysystem.
Product Support
dembkod
Message 3 of 4 (4,105 Views)
11-09-2012 12:37 PM in reply to: danl337
danl337,
Hello. You are likely running an install now and trying to install over the internet. You want to do a direct download instead of this, I believe you can change the download method if you log into the sub center.
Take some things into consideration with your download:
If you are on a wireless connection, plug in.
If you are plugged in, plug into a different terminal.
This is a large file, if your bandwidth takes time, you may want to review your computer sleep settings. If your computer goes into hibernation during a long download- you will likely affect your download.
If this is still a download problem at this stage, I would try a different computer terminal, or move to a different network. Currentlyk, the problem is about a computer not able to download a complete file.
Can you give this a look and let me know how you fare?
Thank you for taking part in our community!
David Dembkoski
Product Support Specialist
Autodesk Product Support
David Dembkoski
New Member
sarptosun
Message 4 of 4 (4,056 Views)
11-12-2012 04:11 AM in reply to: danl337
I have a same problem with that friend. But I didnt understand.
what did you mean by another terminal. Could you explain more detail
I have windows 8.
