Installation & Licensing
New Member
0 Kudos
Post 31 of 136
Re: Communication Failure Error with installation
06-05-2013 01:07 AM in reply to: splaw
Hi Guys, I have the problem solved now with an independent install package.
You can consider my query closed. Thanks for the assistance.
Ciaran
Ciaran O'Brien BARCH MRIAI
DIRECTOR
obfa | ARCHITECTS
O'BRIEN FINUCANE ARCHITECTS
39-40 DAWSON STREET,
DUBLIN 2.
c.obrien@obfa.ie
TEL 353 1 6854586
MOB 353 87 7972921
Note: This message is for the named person's use only. It may contain
confidential, proprietary or legally privileged information. No
confidentiality or privilege is waived or lost by any mis-transmission. If
you receive this message in error, please immediately delete it and all
copies of it from your system, destroy any hard copies of it and notify the
sender. You must not, directly or indirectly, use, disclose, distribute,
print, or copy any part of this message if you are not the intended
recipient. O"BRIEN FINUCANE ARCHITECTS Ltd. reserve the right to monitor all
e-mail communications through its networks. Any views expressed in this
message are those of the individual sender, except where the message states
otherwise and the sender is authorized to state them to be the views of any
such entity.
O'BRIEN FINUCANE ARCHITECTS Registered in Ireland No. 523857
39-40 DAWSON STREET, DUBLIN 2
New Member
0 Kudos
Post 32 of 136
08-14-2013 04:11 AM in reply to: varieth
Welcome. I need to take advantage of the 3DS Max 2014 taken from you, unfortunately, when you run the installer error
http://oi46.tinypic.com/30cbnrn.jpg
I do not have anti-virus or firewall, what should I do?
New Member
0 Kudos
Post 33 of 136
08-14-2013 06:38 AM in reply to: varieth
I am having the same problem getting the "communication failure" message. I have attached a screenshot of my error. You mentioned trying "Download Now or Browser Download". I cannot find those options. If you could direct me to that I will try these alternatives. Otherwise, maybe this problem has been addressed and you can give me tips. I am using WIndows 7 - 64 bit
Thank you,
Marisa
284 Kudos
Post 34 of 136
08-14-2013 09:29 AM in reply to: mrsdsgn
Hello Kurwa and Marisa!
This one could be related to a number of things, including your firewall. Can you try disabling it altogether, or opening these ports.
If that doesn't work I'd recommend using a different download method, specifically the Browser Download option which can be accessed via Matt, our Virtual Agent.
From Matt: Download and Installation -> Software Download Links -> I need to redownload my product
Here to help if additional assistance is needed, otherwise please accept as a solution so that others can benefit from this information!
Philip Schmelzer
Employee
2 Kudos
Post 35 of 136
08-19-2013 12:07 AM in reply to: mrsdsgn
Hi Marisa,
Go back to the Autodesk portal, click on Install Now, after accepting the EULA, a Setup.exe will start getting downloading. Till the time its download finishes, do not click anywhere else on the web page and do not close the web page. Once the downloads finishes, then run the Setup.exe. Wait until the main installer launches.
Once the main installer launches, then you can close the web page. Hopefully, this will resolve your problem.
Thanks & Regards,
Ankush Ved
Employee
2 Kudos
Post 36 of 136
08-19-2013 12:09 AM in reply to: ankushved
Also, in the post you mentioned AutoCAD but in the screenshot the setup.exe is selected for IDSU suite. So, this will not work. You need to launch the Setup.exe which is downloaded for AutoCAD.
Thanks & Regards,
Ankush Ved
New Member
0 Kudos
Post 37 of 136
08-24-2013 12:19 PM in reply to: varieth
I have been trying to install IDSP 2014 for weeks.  Same errors as those previously listed...Communication Failure if I try Install Now and that is with firewall/AV off.  If I download Download Manager nothing happens.  If I spend the excruciating time doing the Browser Download in the four parts.  I always get an error saying some files must be missing.  For the money we spent on this, I find it ridiculous that we do not get the actually CDs since this is obviously so large and cumbersome!
New Member
0 Kudos
Post 38 of 136
09-16-2013 05:27 PM in reply to: varieth
Hye i am trying to download maya 2014 but there seems to be issues with downloading and it just disappers
I using a HP G62 Notebook PC i was wondering if it is the simple fact that my system is a little bit older.
I also tryed 2013 and that one gave me the communication failure error that seems to be so famous among the many people that are in this form. I need this software for my college class.
Active Member
0 Kudos
Post 39 of 136
09-16-2013 06:56 PM in reply to: jjenkins3726
Please use web download. There is no solution besides that.
New Member
0 Kudos
Post 40 of 136
09-24-2013 04:31 AM in reply to: philip.s
I'm having the same problem with Building Design Suite Premuim Trial.
