Installation & Licensing
Member
gareth.h.11
Message 11 of 126 (12,027 Views)
Re: Communication Failure Error with installation
12-21-2012 12:10 AM in reply to: philip.s
Thank tou Phil, I have done that and successfully installed Maya. Thanks again.
New Member
deanjs88
Message 12 of 126 (11,845 Views)
02-15-2013 12:42 PM in reply to: philip.s
I'm encountering the same issue while trying to download the Student Version of Maya 2013. I've tried Install Now and Download Now and neither work. Install now just gives me a file that, when run, only gives me a Communication Error. I tried changing the ports and I even turned off my firewall to try that. When I click Download Now it only gives me the install file for the Autodesk Download Manager, while has already been installed. When I run the DLM a download does not start like the website and all resources I can find suggest. As previously mentioned, I had a bunch of files that had accumulated from the multiple attempts, I deleted those and I'm still encountering this issue. I restarted my computer and repeated everything mentioned, to no avail. Any suggestions?
Member
gareth.h.11
Message 13 of 126 (11,830 Views)
02-16-2013 12:31 AM in reply to: deanjs88
Delete all file you can find related to Maya, then try the browser download option. Keep in mind that it is a different file than the ones you have downloaded previously. That is what worked for me.
New Member
cobrien_obfa
Message 14 of 126 (11,553 Views)
04-22-2013 07:03 AM in reply to: varieth
Hi All, I have been having the same problem trying to download Building Design Suite 2014. I don't have access to the Firewall, so would like to use the Browser download - eh - where do you go for that.
The webpage does not appear to allow it.
Any quick guidance much appreciated.
Ciaran
philip.s
Message 15 of 126 (11,542 Views)
04-22-2013 04:19 PM in reply to: cobrien_obfa
Hello Ciaran,
As the 2014 suite browser download links are not yet available on Matt, our Virtual Assistant (should be within the next couple of days), I'll send you a Private Message (little envelope next to your profile name when signed in) with the corresponding timed links.
Philip Schmelzer
New Member
ayman_hakam
Message 16 of 126 (11,451 Views)
04-26-2013 10:46 AM in reply to: philip.s
I have this message in the attachments when i try to install revit 2014 free trial.
what i can do for this?
philip.s
Message 17 of 126 (11,439 Views)
04-26-2013 03:32 PM in reply to: ayman_hakam
Welcome to the community Ayman!
Take a look at the following Install Now troubleshooting suggestions and let us know if you're able to resolve the issue.
Philip Schmelzer
Active Member
mweiss34
Message 18 of 126 (11,232 Views)
05-07-2013 06:54 PM in reply to: varieth
I'm having the same problem I disable the firewall and tried the advanced settings like discussed.  No luck.  What's this alternative download.  I don't understand
Employee
ankushved
Message 19 of 126 (11,227 Views)
05-07-2013 09:00 PM in reply to: mweiss34
Do not close or refresh the web page once you click Install Now, wait for the <abc>_Setup.exe to get downloaded. Once it downloads, run it. Wait for the main installer screen to appear. Hopefully, this should solve the problem.
Thanks & Regards,
Ankush Ved
Active Member
mweiss34
Message 20 of 126 (11,211 Views)
05-08-2013 10:29 AM in reply to: ankushved
Still not working again I double click on setup.exe.  Windows wants to makes sure I want to install this I say yes.  Autodesk AutoCAD 2014 screen pops up and saids initizing and then I get the communication failure error.  I can't even download the free trail demo from you website because I get a network error from that to.
