I am trying to install Revit architecture educational version, I have downloaded the file to my system but I keep getting communication failure error when trying to install.
Kindly advise please.
Kind regards
I have looked at the link
but I DO NOT have a subscription account to be able to go to the download now page as advised in the link.
Problem still unsolved..
Hi Ahmad,
You can use the "Download Now" option in the Education Community. Please "Accept as a Solution" if this post resolves your issue so that others with this same question can more easily find an answer. If not, please respond to this post with further details. Thank you!
Hi mohuk2007,
Please disable your anti-virus and firewall programs and download the program from our Virtual Agent linked here.
Please accept as solution if my post fully resolves your issue, or reply with additional details if the problem persists.
Hi mohuk2007,
So you mean to say that even downloading from the Virtual Agent you still received a communication failure error message? Are you completely sure that all anti-virus and firewall programs are off? Is your internet connection stable?
Are you using a supported OS?
After the first download failure, did you try uninstalling any existing Autodesk files from your machine before trying again? If not, please do that and then start the download process again, but change your web browser or clear your cookies and cache, disarm your firewall and UAC, and use the Browser Download option. Let us know how it goes!
Hello. This message occurs if you download the “Install Now files” and try to run them from your local drive. Look at the folder you are using and check the properties and size. It should be gigs in size and should have taken an hour or two to download. If it is anything less than over a gig, you do not actually have the installer file.
What you have is not working, go to your c:\Autodesk\ folder and see how many Revit folders you have. Look inside the folders, if you see a link that refers to “install now” delete the whole folder.
I will try to PM you a link.
Thank you for taking part in our community!
