How is it done, for non package license I would simply copy/paste the increment. But since the old license is a packaged and the additional license now is not how would I combine them? Thanks.
Solved by TravisNave. Go to Solution.
Ive just read that a Package License file cannot be combined with an ordinary one. However, is there a way, like, could we request Autodesk to issue a Package license in place of the ordinary license file? Thanks.
Unlikely. But you can do the opposite. You can ask Autodesk to recreate your PACKAGE license file as an ordinary INCREMENT license file. Then you can properly combine your Subscription and non-subscription products. However, you will lose the option of running licenses up to three versions back and only be able to run the current release of your license. If this is not an issue to you, you might consider it.
Yeah its more logical I guess, unless I prefer to shift from a license file to another if I had to use a previous version..That's another good strategy of Autodesk. Atleast now I know my options. Thanks very much.
