Installation & Licensing
Active Member
0 Kudos
Post 1 of 15
Combined package files not working
327 Views, 14 Replies
12-04-2012 08:35 AM
I believe my needs are very simple: I have a package file(12 licenses) for ACAD 2013, 2012, 2100 and 2010. I have another package file (9 licenses) for ACAD 2009, 2008,2007 and 2006. I want to combine these files so I can use my one server for all versions. Both files were generated on the same date. I have followed the tutorials and how-to posts on combining, but the results are always the same: LMTOOLS shows 21 licenses of whichever package is at the top of the file - i.e., if I append the 2009 license info onto the 2013 file, I get 21 licenses of 2013, 2012, 2011 and 2010. If I append the 2013 info onto the 2009 file, I get 21 licenses of 2009, 2008, 2007 and 2006.
Thanks in advance.
were the 2009 products tied to any of the later version of the products?
if the (9) 2009s are on subscription that means they were automatically upgraded to 2010 then 2011, 2012, 2013 if the 2009s serial #s are tied to an active subscription contract you aren't allowed to use them anymore per the Autodesk License agreement you have to  get an exception from autodesk to use them again
so you need to make sure these aren't tied to any of the 2013 serial numbers
651 Kudos
Post 2 of 15
Re: Combined package files not working
12-04-2012 09:15 AM in reply to: robert.mcclellan
are all these on subscription?
651 Kudos
Post 3 of 15
12-04-2012 09:21 AM in reply to: DarrenP
if they are on subscription you copying the package statement from each license file?
Active Member
0 Kudos
Post 4 of 15
12-04-2012 09:36 AM in reply to: DarrenP
Both are subscription products. I'm copying both the PACKAGE and INCREMENT sections from the license file I wish to add.
651 Kudos
Post 5 of 15
12-04-2012 09:49 AM in reply to: robert.mcclellan
try running the license file through this: www.licenseparser.com
to see if it does have the correct numbers
651 Kudos
Post 6 of 15
12-04-2012 10:01 AM in reply to: DarrenP
Active Member
0 Kudos
Post 7 of 15
12-04-2012 10:02 AM in reply to: DarrenP
It's showing what LMTOOLS is reporting - 21 licenses for 2009 to 2006. See attached.
651 Kudos
Post 8 of 15
12-04-2012 10:46 AM in reply to: robert.mcclellan
thats correct
are you also copying the plist information from the 2009 license file?
651 Kudos
Post 9 of 15
12-04-2012 10:49 AM in reply to: DarrenP
somewhere something is not getting copied and pastied correctly
282 Kudos
Post 10 of 15
12-04-2012 11:05 AM in reply to: DarrenP
Hi Robert,
As Darren mentioned above, as this is still on Subscription, your license would be upgraded to 2013 and would permit previous version use of current plus 3 versions back, which matches up with the license file that I see was created yesterday for 12 seats of AutoCAD 2013 (what shows on your attachment as 2009). Did you edit the components by chance?
Additionally, it looks like the other serial number that you are using corresponds to your 2009 license (9 seats), which was upgraded and rolled up into the the 2013 one mentioned above (12 seats).
Philip Schmelzer
