Hello everyone,
I have got a problem during my Vault replication process. I have two servers (Publisher and Subscriber), each one with its own Vault License. When each server manages its own license, everything is working OK. Now, I want to combine them and manage them from one server (the Publisher). I have requested both licenses separately. I have done everything as shown here,
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=8057761&linkID=9240617
but it's still not working. It says that there's only one license. Maybe I haven't configured it properly?
Thanks in advance,
CARLOS CARO
Solved by avto. Go to Solution.
Hi Carlos,
To combine licenses, basically you need to make sure that they are encrypted on the same license server MAC address and then merge files, append one file content to another file content.
Please note that if you are combining the same product version licenses, then both license must be issued on the same date so that license count can add up.
Please let us know if this helps and if not please do not attach your combined license to this post, jut let us know that the issue still persists and we'll open a support case and work with you through the case..
