Hi.
Ive installed AutoDesk Building Desing Suite Premium 2014 +
AutoCAD Architecture 2014 sp 1 + AutoCAD MEP 2014 sp1.
Do I need to install the Autodesk AutoCAD Code Execution Vulnerability – Security Hotfix ID: DL21972896 ??
Thanks in advance.
--Morten
Hello and welcome to the forums Morten,
Readme files for ACA 2014 SP1 and ACAD MEP 2014 SP1 do not indicate that hotfixes are included with them, so you can go ahead and install AutoCAD Code Execution Vulnerability – Security Hotfix.
Hi Morten,
I was just informed that Autodesk AutoCAD Code Execution Vulnerability – Security Hotfix is included with SP1.
So you do not need to install the hotfix if you have installed SP1.
