Installation & Licensing
352 Views, 4 Replies
Closing Idle AutoCAD
Is there any way I can close Idle AutoCAD of network license
users, problem which I am facing is, some users just block the
network licenses hence I want to set-up routine to close
the idle AutoCAD by sending the message or saving the work
if idle time exceeds specific period(i.e. 10Minutes or half an hour)
Uday
4 REPLIES 4
TravisNave
Create a file called adskflex.opt and place it in the same location as your NLM license file (.lic).
This file should contain the following line:
TIMEOUTALL 1800
This will ensure that any AutoCAD that is idle for 30 mins will be released of its license. Or you can change the number to any other time you wish.
You can find more information in the Options File section of the FlexLM user manual.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Sorry one more thing, will the work be save when license is released?
Uday
Don't worry. You will be able to save the work if there is no more licenses
available. If a license is available you will not notice anything.
Best Regards, Jimmy Bergmark
Owner/Senior Developer - JTB World - Software development and Consulting
Blog: http://jtbworld.blogspot.com
JTB FlexReport (FLEXnet / FLEXlm report tool) -
http://www.jtbworld.com/jtbflexreport
SmartPurger (Batch script and purge) -
http://www.jtbworld.com/smartpurger.htm
or download some freeware at http://www.jtbworld.com
More on AutoCAD 2006 and 2007
http://www.jtbworld.com/autocad2006.htm
http://www.jtbworld.com/autocad2007.htm
wrote in message news:5308484@discussion.autodesk.com...
Uday
Administrator Productivity
