I am looking to free up space on my C:\ drive after installing Inventor, and was wondering about the C:\Autodesk\Autodesk_PRDSU_2013_English_Win_64bit folder. The folder is 32.9 GB and it appears that it is simply the unpacked setup files from the install CD and therefore not essential for everyday use. Does anyone know what the purpose of this folder is and whether or not I can remove it?
Thanks in advance,
Russ
Solved by TravisNave. Go to Solution.
Solved by JTBWorld. Go to Solution.
If you have the install media you can safely delete this folder.
Jimmy is right. If you don't, archive this data because you'll have to download it all again if you need to reinstall or repair.
