Installation & Licensing
Member
0 Kudos
Post 1 of 6
Civil3D Installation Failure
341 Views, 5 Replies
03-22-2013 07:17 PM
I've read some of the other threads, disabled my AV software, deleted my temp files.  Still didn't work.
Here's my installation log.
2013/3/22:19:57:31 Damien DAMIEN-LAPPY === Setup started on DAMIEN-LAPPY by Damien === 2013/3/22:19:57:31 Damien DAMIEN-LAPPY Launch 2013/3/22:19:57:52 Damien DAMIEN-LAPPY === Setup ended ===
2013/3/22:19:57:50 Damien DAMIEN-LAPPY === Setup started on DAMIEN-LAPPY by Damien === 2013/3/22:19:57:50 Damien DAMIEN-LAPPY Launch 2013/3/22:19:57:50 Damien DAMIEN-LAPPY Download Skipped SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/CIV3D/WI/{11D2C4DA-D55B-42E4-BBAB-7748D34525DB}/S... 2013/3/22:19:57:51 Damien DAMIEN-LAPPY PageOpen LaunchDialog   2013/3/22:19:58:16 Damien DAMIEN-LAPPY PageOpen LicenseDialog   2013/3/22:19:58:35 Damien DAMIEN-LAPPY PageOpen ProductInfoDialog   2013/3/22:19:59:18 Damien DAMIEN-LAPPY PageOpen ProductSelectionDialog2   2013/3/22:19:59:28 Damien DAMIEN-LAPPY PageOpen FullProgressDialog   2013/3/22:19:59:28 Damien DAMIEN-LAPPY Download Skipped DIRECTX http://studentsdownload.autodesk.com/SWDLDDLM/2013/CIV3D/WI/{11D2C4DA-D55B-42E4-BBAB-7748D34525DB}/D... 2013/3/22:19:59:28 Damien DAMIEN-LAPPY Installing DirectX Runtime: C:\Autodesk\WI\AutoCAD Civil 3D 2013\3rdParty\DirectX\DXSETUP.exe /silent 2013/3/22:20:00:06 Damien DAMIEN-LAPPY Install DirectX Runtime Succeeded  2013/3/22:20:00:06 Damien DAMIEN-LAPPY Installing FaroSDK:   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD Civil 3D 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/3/22:20:00:28 Damien DAMIEN-LAPPY Install FaroSDK Succeeded  2013/3/22:20:00:28 Damien DAMIEN-LAPPY Download Skipped CM2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/CIV3D/WI/{11D2C4DA-D55B-42E4-BBAB-7748D34525DB}/C... 2013/3/22:20:00:28 Damien DAMIEN-LAPPY Installing Autodesk Material Library 2013:   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD Civil 3D 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/3/22:20:01:09 Damien DAMIEN-LAPPY Install Autodesk Material Library 2013 Succeeded  2013/3/22:20:01:09 Damien DAMIEN-LAPPY Download Skipped CMILB2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/CIV3D/WI/{11D2C4DA-D55B-42E4-BBAB-7748D34525DB}/C... 2013/3/22:20:01:09 Damien DAMIEN-LAPPY Installing Autodesk Material Library 2013 - Low Resolution:   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD Civil 3D 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/3/22:20:01:50 Damien DAMIEN-LAPPY Install Autodesk Material Library 2013 - Low Resolution Succeeded  2013/3/22:20:01:50 Damien DAMIEN-LAPPY Installing Autodesk Content Service:  INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS="C:\Autodesk\WI\AutoCAD Civil 3D 2013\x64\en-us\Tools\snap\ContentService.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD Civil 3D 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/3/22:20:02:07 Damien DAMIEN-LAPPY Install Autodesk Content Service Succeeded  2013/3/22:20:02:07 Damien DAMIEN-LAPPY Installing Autodesk Content Service Language Pack:  ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD Civil 3D 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/3/22:20:02:17 Damien DAMIEN-LAPPY Install Autodesk Content Service Language Pack Succeeded  2013/3/22:20:02:17 Damien DAMIEN-LAPPY Installing SQL Server CE 3.5 x86:   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD Civil 3D 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/3/22:20:02:26 Damien DAMIEN-LAPPY Install SQL Server CE 3.5 x86 Succeeded  2013/3/22:20:02:26 Damien DAMIEN-LAPPY Installing SQL Server CE 3.5 x64:   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD Civil 3D 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/3/22:20:02:31 Damien DAMIEN-LAPPY Install SQL Server CE 3.5 x64 Succeeded  2013/3/22:20:02:31 Damien DAMIEN-LAPPY Download Skipped VBPOWERPACK http://studentsdownload.autodesk.com/SWDLDDLM/2013/CIV3D/WI/{11D2C4DA-D55B-42E4-BBAB-7748D34525DB}/V... 2013/3/22:20:02:31 Damien DAMIEN-LAPPY Installing Microsoft Visual Basic Power Packs 10.0: C:\Autodesk\WI\AutoCAD Civil 3D 2013\3rdParty\VBPowerPacks10\VisualBasicPowerPacksSetup.exe /q /l C:\Users\Damien\AppData\Local\Temp\VisualBasicPowerPacks10Setup.log 2013/3/22:20:02:36 Damien DAMIEN-LAPPY Install Microsoft Visual Basic Power Packs 10.0 Succeeded  2013/3/22:20:02:42 Damien DAMIEN-LAPPY Download Play C3D http://studentsdownload.autodesk.com/SWDLDDLM/2013/CIV3D/WI/{11D2C4DA-D55B-42E4-BBAB-7748D34525DB}/C... 2013/3/22:20:12:17 Damien DAMIEN-LAPPY Download Aborted C3D http://studentsdownload.autodesk.com/SWDLDDLM/2013/CIV3D/WI/{11D2C4DA-D55B-42E4-BBAB-7748D34525DB}/C... 2013/3/22:20:12:17 Damien DAMIEN-LAPPY Install AutoCAD Civil 3D 2013 Failed Download Failed, Installation aborted, Result=1603 2013/3/22:20:12:18 Damien DAMIEN-LAPPY Rollback Microsoft Visual Basic Power Packs 10.0 Failed Failure is ignored, Result=1619 2013/3/22:20:12:23 Damien DAMIEN-LAPPY Rollback SQL Server CE 3.5 x64 Succeeded  2013/3/22:20:12:29 Damien DAMIEN-LAPPY Rollback SQL Server CE 3.5 x86 Succeeded  2013/3/22:20:12:34 Damien DAMIEN-LAPPY Rollback Autodesk Content Service Language Pack Succeeded  2013/3/22:20:12:46 Damien DAMIEN-LAPPY Rollback Autodesk Content Service Succeeded  2013/3/22:20:13:13 Damien DAMIEN-LAPPY Rollback Autodesk Material Library 2013 - Low Resolution Succeeded  2013/3/22:20:13:52 Damien DAMIEN-LAPPY Rollback Autodesk Material Library 2013 Succeeded  2013/3/22:20:13:56 Damien DAMIEN-LAPPY Rollback FaroSDK Succeeded  2013/3/22:20:13:56 Damien DAMIEN-LAPPY Rollback DirectX Runtime Failed Failure is ignored, Result=1619
Hi callmestick,
Yes, you can install the program from your CD and activate it with the product info you obtained from the Education Community.
Best regards,
902 Kudos
Post 2 of 6
Re: Civil3D Installation Failure
03-25-2013 08:55 AM in reply to: callmestick
The program is not finishing downloading.  This may be a problem with the student site.  You might try another computer or try it later to see if it works.
Member
0 Kudos
Post 3 of 6
03-25-2013 09:16 AM in reply to: callmestick
Oh, good to know.  We had internet problems this weekend and they came and fixed it yesterday so I will try again.
Thankyou.
Member
0 Kudos
Post 4 of 6
03-27-2013 05:56 AM in reply to: callmestick
I tried again last night both on a hard line and wireless and got to the exact same point and the download failed again.
If I have access to a CD, can I install with the CD using my student serial number and product key?
179 Kudos
Post 5 of 6
03-27-2013 06:16 AM in reply to: callmestick
Hi callmestick,
Best regards,
Camilo Lemos
Member
0 Kudos
Post 6 of 6
03-27-2013 06:52 AM in reply to: camilo.lemos
Awsome, I'll just do that.   Thanks.
