I am a reseller and picked up an issue with Flexlm 11.12 iPv6 x64 version
A customer runs Civil3D 2014 and 2015 on the same machine and it takes up 2 licenses from what is available
I tried on my own machine and found it is true as shown in the Status Enquiry below
This should not happen as with DUP_GROUP=UH in the license file this should only take up one license from the server per username.
It then denies licenses to other users (adskflex) DENIED: "64900CIV3D_F" TC02@TC02-PC (Licensed number of users already reached. (-4,342))
With license files up to and including 2014 versions this was never a problem with PACKAGE licenses
Any ideas or is this a bug?
Users of 64900CIV3D_F: (Total of 2 licenses issued; Total of 2 licenses in use)
"64900CIV3D_F" v1.000, vendor: adskflex floating license
Olaf Olaf-Z400 Olaf-Z400 (v1.000) (OLAF-Z400/27000 301), start Mon 6/23 16:04 Olaf Olaf-Z400 Olaf-Z400 (v1.000) (OLAF-Z400/27000 104), start Mon 6/23 16:04
Users of 86354CIV3D_2015_0F: (Total of 2 licenses issued; Total of 1 license in use)
"86354CIV3D_2015_0F" v1.000, vendor: adskflex floating license
Olaf Olaf-Z400 Olaf-Z400 (v1.0) (OLAF-Z400/27000 401), start Mon 6/23 16:04
Users of 86173CIV3D_2014_0F: (Total of 2 licenses issued; Total of 1 license in use)
"86173CIV3D_2014_0F" v1.000, vendor: adskflex floating license
Olaf Olaf-Z400 Olaf-Z400 (v1.0) (OLAF-Z400/27000 204), start Mon 6/23 16:04
Solved by DarrenP. Go to Solution.
opening 2 different versions of the same product has always taken 2 licenses
DarrenP
Hi Darrenp
I double-checked using an older license manager and you are correct.
One would think that with the Package option one computer would consume 1 license on 1 machine. It seems that only applies to multiple instances running of the same version.
Thanks for feedback.
