Installation & Licensing
martin.franc
Message 3 of 13 (305 Views)
Civil3D 2013 GPO issue
305 Views, 12 Replies
04-30-2012 08:24 AM
i dont have described problem a ihave problem with finish installation procedure. AD/GPO procedure completed via  http://wikihelp.autodesk.com/Alias/enu/2013/Help/0000-Alias_In0/0001-Install_1/0002-Before_y2/0115-N... with cs-cz lang version. After installation i try launch program via "AutoCad LT 2013 české prostředí". Autorun postinstallation process trying install files for actual loged user. In this moment installation process crash without any log in protocol.
Edited by
Discussion_Admin
martin.franc
Message 1 of 13 (316 Views)
Re: Civil3D 2013 GPO issue
04-30-2012 06:12 AM in reply to: hashim.mundol
Hi, i have similar issue with application AutoCad 2013 and AutoCad LT 2013. Installation v2013 via AD/GPO not working, but previous version works fine (2009-2012). Some progress?
Product Support
hashim.mundol
Message 2 of 13 (313 Views)
04-30-2012 06:28 AM in reply to: hashim.mundol
Hi Martin Franc
This issue was with Civilt 3D 2013. AutoCAD 2013 works fine on our test machines.
Can you give some details on the error please.
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
For more tips & tricks: http://upandready.typepad.com
Hashim Mundol
Autodesk Product Support
Product Support
hashim.mundol
Message 4 of 13 (304 Views)
04-30-2012 11:12 AM in reply to: hashim.mundol
This might be a different isue.
Are you able to get verbose log for the installation
http://support.microsoft.com/kb/223300
Hashim Mundol
martin.franc
Message 5 of 13 (282 Views)
05-01-2012 11:53 PM in reply to: hashim.mundol
Hi, I have extended logs. Where can I send?
Product Support
hashim.mundol
Message 6 of 13 (275 Views)
05-02-2012 12:19 AM in reply to: martin.franc
Please zip and attach the file here. If the size is big we will open a case for you.
Hashim Mundol
martin.franc
Message 7 of 13 (267 Views)
05-02-2012 04:53 AM in reply to: hashim.mundol
sending...
martin.franc
Message 8 of 13 (263 Views)
05-02-2012 05:45 AM in reply to: hashim.mundol
Small (big) update info. I download pure EN version of LT2013. Use same prerequisites (VC version, .NET, DX, etc). Same instalation process via AD/GPO. EN version working. There is a log.
Product Support
hashim.mundol
Message 9 of 13 (260 Views)
05-02-2012 06:21 AM in reply to: martin.franc
I looked at the logs, this is the specific error in the log
Akce ukončena 8:41:42: RestoreAdskSharedProperties. Vrácená hodnota: 3.
Akce ukončena 8:41:42: INSTALL. Vrácená hodnota: 3.
MSI (s) (74:08) [08:41:42:514]: Produkt: AutoCAD LT 2013 – Čeština (Czech) -- Konfigurace se nezdařila.
MSI (s) (74:08) [08:41:42:524]: Instalační služba systému Windows provedla opětovnou konfiguraci produktu. Název produktu: AutoCAD LT 2013 – Čeština (Czech). Verze produktu: 19.0.55.0. Jazyk produktu: 1029. Stav opětovné konfigurace (úspěch nebo chyba): 1603.
Did you install all the pre-requisites ?
Have you tested the installation manually on the same machine ?
1603 is generic permission issue. it could the System account has some restrictions on the machine.
Hashim Mundol
martin.franc
Message 10 of 13 (256 Views)
05-02-2012 06:41 AM in reply to: hashim.mundol
In this testing environment are no restriction to security. All installation are tested with domain admin rights. Maybe there's some problem with "ADSK content service" and CZ lang package. I try check something... EN version works fine.
