Installation & Licensing
Civil3d 2012 - DACH Extensions silent install (Active Setup?)
1 REPLY 1
support
992 Views, 1 Reply
hi there
We've got some problems with the DACH Extensions for Civil3d 2012. I saw you can add the DACH Extensions to the Deployment file of Civil3d. The problem now is, that the user which is logged in has no administrative right (At first logging the UAC shows up,that DACH Extensions will be installed).
Is there a solution out there to install DACH Extensions just one time on a computer and not per user?
Other possibility:
Can we store the DACH Extension files somewhere locally and add a Support Folder Path in Civil3d that loads the Extension?
Thanks for help
regards
andi
1 REPLY 1
Christian_Bauer
in reply to: support
Hi Andi,
I can only refer to our Technical Solution:
Einrichtung der AutoCAD Civil 3D "DACH Extension" unter einen neuen Windows Benutzer
Which basically says, that you have to install the DACH Extension for every Windows User you are trying to use the DACH Extension.
HTH
Christian Bauer
Administrator Productivity
