Hi all,
We've been running the FlexLM license server for our LDD, Acad, Civil, and Survey, applications for some time without problem.
Today though, the Civil extension for LDD will not pull a license, unless the "Browse for license file" option is selected, and manually pointed to the license file.
FlexLM is running on a Win2k box, and the service is still running. LDD, AutoCAD, Acad Map, all load fine, it's just Civil and Survey. The IP and hostname haven't changed, and all the licenses are in the same *.lic file
Once a client is pointed to the server, they run fine, but they used to work normally without a client having to do this.
I re-started the server, and the services.
Any suggestions on fixing this?
Thanks!
