Hi guys, I wanted to move my postes to this board. It seems mybe this is the place to find the answer?
http://forums.autodesk.com/t5/AutoCAD-Civil-3D/Civil-3d-2010-wont-open/td-p/2784676
Solved by vivekramesh. Go to Solution.
Have a look at the thread below which adresses similar a similar issue
http://forums.autodesk.com/t5/Installation-Licensing/i-can-not-operate-my-autucad/td-p/2757591
PROBLEM SOLVED!!
Thanks Vivek! And thanks to all that responded previously. It turns out, after applying the fix and launching C3d 2010 again, it had actually never launched correctly at all. Even on previous uses, I have access to menus and ribbons I hadn't seen before. Thanks All. There is absolutely no substitute for the power of this knowledge base of users and Technicians.
