I have created a deployment on our server for 64 Bit but need to have one also for a 32 Bit machine. During the deployment I can only select the 64 Bit. The DVD has 64 Bit on it, does that mean I only 64 Bit capabilities? Do I need to contact my reseller and get another DVD?
Solved by DarrenP. Go to Solution.
Hello Tim,
Civil 3D 2014 is only 64bit. see the following:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=15411638&linkID=9240697
Hope the above helps to anser your inquiry.
autodesk discontinued the 32 bit versions of some of their products
DarrenP
