Installation & Licensing
Civil 3D 2013 - Trying to add custom files to the deployment
1 REPLY 1
Dylan_Corkill
570 Views, 1 Reply
I'm working on setting up a deployment for civil3d 2013.  We have a custom acad.exe.config file and a modified custom.cui.   Where do I add these in when working on setting up the deployment?   In Autocad we can see the full installation paths of where all the files go but I don't see that in Civil 3d.  So again how can I add these files in.
Dylan
1 REPLY 1
avto
in reply to: Dylan_Corkill
Hi Dylan,
Unfortunately, AutoCAD C3D 2013 deployment creation wizard doesn’t support adding customized files to the deployment image.  You can try creating a default deployment image and replaying the original files with your customized files and see if that helps.
acad.exe.config can be found in:
\\your_network_share_name\AdminImage\x64\C3D\Program Files\root\C3D_AppRootOverrides
custom.cuix can be found in:
\\your_network_share_name\AdminImage\x64\en-us\C3D\Acad\Program Files\root\UserDataCache\en-us\Support
Here is the link to another post regarding customizing C3D deployment that may help as well.
http://forums.autodesk.com/t5/Installation-Licensing/Civil-2102-Custom-Paths-Enterprise-CUIX-and-Cus...
Avto Chachava
Autodesk Product Support
Autodesk, Inc.
Administrator Productivity
