This SP was pulled shortly after initial posting, and I believe I have it installed and not the one that was subsequently posted. How can I tell for sure. When I try to install the most recent SP2.1, I get a message that says I'm up to date, but I'm not convinced. Is there a registry entry that I can check to be sure? Or somewhere in the About dialog?
Hi LisaPohlmeyer,
I believe you can check the Service Pack (SP) or Hotfix (HF) status under the Help-About option, under the Serial Number. Refer to the attached.
Abbreviation used:
SP - Service Pack
HF - Hotfix
Version/Update - Service Pack
