Does anyone know in what order the following Autodesk software should be installed so that everything works properly ?
AutoCAD Civil 3D 2010
AutoCAD Raster Design 2010
AutoCAD Raster Design 2010 Object Enabler
Subscription Advantage Pack for AutoCAD Civil 3D 2010
Stage Storage Extension for AutoCAD Civil 3D 2010
AutoCAD Civil 3D 2010 Update 1
AutoCAD Civil 3D 2010 Update 2
AutoCAD Civil 3D 2010 Update 3
TIA
Here is the recommended install order:
- Re-download this installer if you have not done so recently there was a prerelease that Update 3 will not install onto.
- AutoCAD Civil 3D 2010 Update 2 is required before you install the Subscription Advantage Pack.
You will not need the AutoCAD Raster Design 2010 Object Enabler because it is already in AutoCAD Raster Design 2010. The OE would only be necessary for those computers that you do not install the full AutoCAD Raster Design 2010.
We installed in that order, everything seems good.
The Raster Design OE is needed on these machines when we run "AutoCAD Civil 3D 2010 as AutoCAD" since RD does not load.
Please, do not install the AutoCAD Raster Design Object Enabler if you have already installed AutoCAD Raster Design.
Add these Support File Search Paths to your “AutoCAD” profile in AutoCAD Civil 3D 2010:
- C:\program files\raster design 2010 oe
- C:\program files\common files\autodesk shared\axui
- C:\program files\autocad raster design 2010\help
Also load this Partial CUI:
C:\Documents and Settings\%username%\Local Settings\Application Data\Autodesk\ARD2010\R18.0\enu\Support\AecCo.cuix
If you have an AutoCAD 2010 or vertical installed side by side with a previous release you may need to follow this solution to remove AutoCAD Raster Design folders from the Windows PATH environment Variable and add it to the AutoCAD Support File Search Path.
