a few things could cause this:
a) your Name resolution isn't working. Try adding an environmentvariable to
your OS:
ADSKFLEX_LICENSE_FILE
give it a value that reflects the IP-address of the licenseserver
b) you are accessing the network through a firewall (or have one on your pc.
Check the the ports:
27000
2080
are both open.
HTH
Petri Ahava
CAD-Q Finland
"Steve Stafford" wrote in message
news:39B485470002C4B1099197BB27A45537@in.WebX.maYIadrTaRb...
> They did just legitimize WAN use though didn't they? Isn't that the press
> release I read recently, accounting for a larger fee for network licensed
> versions?
> Steve
> "James Wedding" wrote in message
> news:10BE978BF23D54D01201394DE6522A17@in.WebX.maYIadrTaRb...
> > you'll have to check the ports available at work. Last I heard, FlexLM
has
> > to be able to to ping in both directions by IP and name. This could
cause
> > the problem.
> > Part of the problem is that autodesk doesn't officially support WAN
> access,
> > so it's hard to get good clear information. Keep searching, I think
there
> > are some older posts that ahd step by step solutions.
> > Good luck!
> > James Wedding, P.E.
> > IT Manager
> > Jones & Boyd, Inc.
> > Dallas, TX
> > jwedding@*NOSPAM*jones-boyd.com
> > Search before you ask, it's been asked before.
