Installation & Licensing
Changing License Server Name
6 REPLIES 6
rossg59
1897 Views, 6 Replies
I am changing the name of the server which hosts the FlexLM for our network license of AutoCAD 2006. Can I simply change the name of the server in the license file or do I have to get a new license file? Thanks.
6 REPLIES 6
in reply to: rossg59
You need a new license file.
Jimmy Bergmark
JTB World - Software development and consulting
Owner/Developer
http://www.jtbworld.com
http://jtbworld.blogspot.com
JTB World offers you software's, custom software development, consulting...
http://www.jtbworld.com/about.htm
JTB FlexReport (FLEXnet / FLEXlm license report tool) -
www.jtbworld.com/jtbflexreport
AutoCAD 2009
http://www.jtbworld.com/autocad2009.htm
"rossg59" skrev i meddelandet news:5876491@discussion.autodesk.com...
> Thanks.
mahahaavaahava
I always thought that the license was only bound to the MAC-address? There was even a KB article for this scenario when Flex first came with AutoCAD:
http://usa.autodesk.com/adsk/servlet/ps/item?siteID=123112&id=2886477&linkID=9240617
Please correct me if I'm wrong!
/Petri
You're right from from what I can see in the KB and this one.
http://usa.autodesk.com/adsk/servlet/ps/item?siteID=123112&id=2886471&linkID=9240617
Jimmy Bergmark
Owner/Developer
AutoCAD 2009
skrev i meddelandet
news:5877338@discussion.autodesk.com...
> Hi,
> /Petri
mahahaavaahava
So in fact:
Change away. Safest is to use the LMTOOLS to check exactly how Flex sees the name: System Settings --> Computer/Host name
/Petri Message was edited by: petri_ahava@msn
TravisNave
If you simply change the name, the NLM will fail. You will need to modify your license .lic file and replace the hostname listed there with the following special name: this_host
That should keep your NLM running.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
This is actually the safest thing to use in most cases unless you have
specialized requirements. It avoids you from a number of possible problems.
Not too many do this though.
Best regards,
Henrik Goldman
Flexlm license management to reduce your costs -
http://www.x-formation.com/license_statistics/index.html
Knowledgebase on software license management - http://kb.x-formation.com/
Protect your software with LM-X License Manager -
http://www.x-formation.com/lm-x_license_manager/index.html
Administrator Productivity
