I've got a bit of a problem with moving autodesk licenses from one serve to another one. To be exactly, it's not the actual process of moving the licenses (that was really simple) but now I've to re-configure the clients. Let's assume the following situation:
Old license server FQDN: DCXB1
New license server FQDN: DCXB2
Where can I change the license server at the clients? Or do I have to reinstall everything? I've already changed the administrative sources for network installation, that works perfectly, but I'd like to avoid a re-installation for all the "old" clients cause it's a hell of a work 😉 .
All suggestions appreciated. Thanks for your efforts in advance.
Regards
Stephan
Solved by frhervet. Go to Solution.
See this article :
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=8385605&linkID=9240617
@DCXB2
