Installation & Licensing
Change IP / FQDN of license server
2 REPLIES 2
stephan_1975
771 Views, 2 Replies
I've got a bit of a problem with moving autodesk licenses from one serve to another one. To be exactly, it's not the actual process of moving the licenses (that was really simple) but now I've to re-configure the clients. Let's assume the following situation:
Old license server FQDN: DCXB1
New license server FQDN: DCXB2
Where can I change the license server at the clients? Or do I have to reinstall everything? I've already changed the administrative sources for network installation, that works perfectly, but I'd like to avoid a re-installation for all the "old" clients cause it's a hell of a work 😉 .
All suggestions appreciated. Thanks for your efforts in advance.
Regards
Stephan
2 REPLIES 2
frhervet
in reply to: stephan_1975
See this article :
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=8385605&linkID=9240617
  • In the Variable Name box, enter ADSKFLEX_LICENSE_FILE
  • In the Variable Value box, enter the license server(s) in the following format:
  • @DCXB2
Franck Hervet
S'il vous plaît Marquer cette réponse comme "Accepter comme solution" si elle répond à votre question.
stephan_1975
Thanks a lot, that was the solution! Smiley Happy
Administrator Productivity
