it seems with Inventor 2009 Sim suite there are some things that you must
do locally and then other things you cannot change in the image after it is
created. Like, the content library seems like it must be installed
locally??
also, it appears that you need the design review installed to use
multi-sheet plot, but you cannot add it to an existing image??
If you really cant add it to and existing image, can you create new image
with the same name... and just update the clients to it easily?
