Installation & Licensing
Member
kristinwinters1
Message 1 of 3 (155 Views)
CER_81270302
155 Views, 2 Replies
06-17-2013 10:52 AM
I have tried installing Autodesk Building Design Suite Premium 2014  everyway possible (download, install, browser install, and even orderded the USB drive from Autodesk) and none work.  I start set up and while it still says "initializing" an error window pops up and says Autodesk has encountered a problem and needs to shut down.  Then the error report brings up the following code: CER_81270302. I cannot figure out what the problem is or how to fix it.  Can anyone help????
To follow up on this case the root cause was the presence of the "Displaylink Core Software". Removing it from the system resolved the issue.
More info on this at the below link
http://upandready.typepad.com/up_and_ready/2012/05/general-installation-dlumd32dll-displaylink-core-software.html
TravisNave
Message 2 of 3 (149 Views)
Re: CER_81270302
06-17-2013 11:08 AM in reply to: kristinwinters1
Welcome to the boards Kristin! :smileyhappy:
When it comes to installing the software, I generally recommend the following:
1.  Your user account has local admin rights to the machine, or you login with Administrator.
2.  You Disable UAC.  (requires reboot)
3.  You Disable Anti-Virus
You might even create a new user on your machine as an administrator and install as that user.
If it still fails, you might have some sort of malware infection and/or your Windows files need updated with Windows Update.
Don't give up!
Product Support
asburyj
Message 3 of 3 (118 Views)
Re: CER_81270302
06-20-2013 04:19 PM in reply to: TravisNave
http://upandready.typepad.com/up_and_ready/2012/05/general-installation-dlumd32dll-displaylink-core-...
Jeffry Asbury
