Installation & Licensing
toconnor13
241 Views, 3 Replies
CaseNo:08150324.
We have submitted this issue last week but have not received a resolution. All of the sudden, we were asked to activate our AutoCAD LT 2008 license even though we've been using it for years on the same Windows 7 Pro - 64 bit machine. We did not have any hardware and software changes.
Here is the case number: 08150324.
Help!
3 REPLIES 3
TravisNave
in reply to: toconnor13
Though LT 2008 is not supported on Windows 7, I suspect that this may be your issue:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=5620053&linkID=9240818
It plagued many installations during that time frame.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
toconnor13
in reply to: TravisNave
The fix did not help. Still got the following message:
Activation Limit Reached - Error (10)
TravisNave
The fix probably will help prevent this in the future.  Your existing error now is that the automatic system has locked you out.
Get an activation code manually.
You can use the online method to activate your license here:
http://usa.autodesk.com/adsk/servlet/pc/item?id=18424632&siteID=123112
Or you can can call Autodesk Product Registration and Authorization:
http://en.autodesk.ca/adsk/servlet/index?siteID=9719649&id=9830778
1-800-551-1490 > Option 1 (English) > Option 1 > (Stand-alone)
Asia / Pacific: 65.6735.5688
Europe / Middle East / Asia: 41.32.723.9595
You will need to provide your serial number and the request code.
Autodesk Forums:
Administrator Productivity
