Installation & Licensing
Cascading for Navisworks Manage and Simulate
5 REPLIES 5
david.lau
732 Views, 5 Replies
Information on the cascading of licenses of Autodesk products is here:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=14885918&linkID=12305695
For Navisworks, you need will need to install both the Manage and Simulate on the same computer if you would like to use either the Manage or Simulate license from the license server.
1. Navisworks Manage will only use a Manage license.
2. Navisworks Simulate will use either a Manage or Simulate license.
3. If you open Navisworks Simulate and it uses a Manage license before using a Simulate license, you can flip the order of the licenses in the license file or you can create an options file for the license server.
4. Navisworks Simulate should use a Simulate until it runs out of Simulate licenses then it will use a Manage license, if available.
David Lau
5 REPLIES 5
cosmin.petrea
in reply to: david.lau
Hi, does that mean the with an AEC Collection/Navisworks manage license or any other license that includes Navisworks Manage I am entitled to install and use Navisworks Simulate?
Thank you,
Cosmin
DarrenP
in reply to: cosmin.petrea
this post was from nearly 10 years ago so things may have changed since then
how cascading works for collections: https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Cascad...
you will have to try installing simulate & see if it will grab a collection license or a manage license
DarrenP
cosmin.petrea
in reply to: DarrenP
Hi DarrenP,
Thank you for the quick reply.
I understand the technicalities, but my question is rather a licensing one.
So, from a licensing perspective, is it permitted to install and use Navisworks Simulate and assign a Navisworks Manage license to the user/device that uses the Simulate software?
In short, is it possible to assign a Navisworks Manage license to cover the use of Navisworks Simulate (from a licensing perspective and not technical one)?
Just to elaborate a bit more, all functionalities of Simulate are included in Manage, and the price of Manage is 2.5 times higher, but is not clear for me if a Navisworks Manage license includes the use rights of Navisworks  Simulate.
Thank you,
Cosmin
DarrenP
this post is talking about multi-user licensing not single user licensing
so no you won't able to  assign a manage license to cover a simulate license
DarrenP
cosmin.petrea
This is exactly the case: using AEC network licenses.
AEC includes Navisworks Manage, but it is not clearly stated if Manage includes Navisworks Simulate.
So the question is, when in an multi-user licensing scenario, if one of my users have an AEC license assigned by the licensing server and have installed locally the Simulate software, should we purchase a separate license for Navisworks Simulate, or the use of Navisworks Simulate comes included in the AEC licenses (which includes Navisworks Manage)?
Administrator Productivity
