Installation & Licensing
Cant Reinstall autodesk products after uninstalling.
11 REPLIES 11
Message 1 of 12
aaronno1998
367 Views, 11 Replies
hello, im using windows8.1 after i deleted inventor2014 i want to install it again the installer says it already installed
i've contacted autodesk on twitter but they cant help me with their suggestions
i have send a picture too
i hope somewone can help me
11 REPLIES 11
Message 2 of 12
D2BGR8
in reply to: aaronno1998
You will need to go into your system and manually remove all traces of Autocad files. Go into the system registry files and everywhere you will see an autocad file or extension, take them all out before you will be able to reinstall. It is time consuming but worth it.
Wishing you good luck -
Message 3 of 12
aaronno1998
in reply to: D2BGR8
already tried
no result 😞
Message 4 of 12
D2BGR8
Use the "regedit" command to go into your registry... Open every file there and look for autocad related stuff and remove them 1 after the other. Takes time...
Message 5 of 12
abnerparedesii
in reply to: D2BGR8
what to delete is Registry?
Message 6 of 12
D2BGR8
in reply to: abnerparedesii
use the "regedit" command to go into your registry files.
YOu are NOT deleting the registry itself. But you are looking into the files which are in the registry.
Message 7 of 12
abnerparedesii
in reply to: D2BGR8
thats Scary man especially if you dont know what to delete. :c
Message 8 of 12
aaronno1998
im computer engineer so i know what to delete but i cant find my solution in my install error
Message 9 of 12
pendean
Reformat your HD and start all over.
Message 10 of 12
aaronno1998
in reply to: pendean
i dont like that at all
Message 11 of 12
abnerparedesii
that might beh a good solution but the time that itll take to install all over again.. autodesk has no fix on this yet
Message 12 of 12
pendean
You've wasted that much time here "waiting"... .
Administrator Productivity
