Installation & Licensing
Cant Install Mudbox 2014! Help Please!
3 REPLIES 3
joaonamaia
787 Views, 3 Replies
 I am having problems installing Mudbox 2014. Firts i installed Mudbox, and it worked perfectly, but then, i had to shut down my computer, while Mudbox was open.
 And then, when i tried to execute Mudbox2014, it wouldnt run. Then i searched in the Internet for solutions, and i read that i should delete all temp files.
 And i did that. But still didint work. So i unnistalled Mudbox, and downloaded and tried to install it again. but when i was tryng to install it on my pc, this appeared.
 And it wont letme install on my pc. I really dont understand why.
And when I try to "Install Tools and Utilities", it says "System cant open device or specified file. C:\Autodesk\WI\Autodesk Mudbox 2014\x64\Tools\NLM\NLM.msi"
 If anyone could help me, i would appreciate it. Thank you!
3 REPLIES 3
Darin.Green
in reply to: joaonamaia
You need to redownload the software because those files within the 'WI" folder are nolonger good. This is caused by using the "Install Now" option when downloading. Choose "Download Now" from the download drop down list.
If this information was helpful, please consider using the Accept Solution
joaonamaia
in reply to: Darin.Green
Sem Título-1.jpg Okay, I did what you said, and, I COULD FINALLY DOWNLOAD AND INSTALL MUDBOX 2014, and for that, i thank you.....
 But... When i trie to execute Mudbox 2014, it doesnt do anything, it simply doesnt execute...
 Can you, or anyone else help me on this problem? Please help! Thank you!
Darin.Green
You could have a corrupted mudbox profile. Create a new local user on the machine and see if you can login with that account and launch mudbox.
Administrator Productivity
