Installation & Licensing
Vitornis
185 Views, 3 Replies
Cant install MEP 2011
This computer used to have MEP 2011 installed on it and now im trying to reinstall it as a back-up workstation. i can't get it to install because it says it is already installed.  It is not listed in the Uninstall program list either.
3 REPLIES 3
jcampbell924
in reply to: Vitornis
We have had this happen before on several Autodesk products.  I would suggest following the below Autodesk KB.  As a last resort google "Microsoft MSI cleanup  utility".  We sometimes have to run this in order to clean up installs after they have not removed correctly.  I will caution you though to only select the Autodesk products from the list when using the tool.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2887771&linkID=9240617
Vitornis
I tried everything in the link and it didn't help any.
jcampbell924
Did you try looking for the Microsoft Windows Install cleanup utility?
http://technet.microsoft.com/en-us/magazine/2008.08.utilityspotlight.aspx
Past that you may want to open a ticket with Autodesk Support.  I was talking with one of the AMEP support tech's that I know out at Autodesk University and he mentioned some hidden reg key's that they had just found dealing with Windows 7 and the Install engine that they use.  I wonder if these are causing your issue.
Administrator Productivity
