Hi i just formatted my computer and mayb i havnt downloaded the stuff that i have to for the AutoCAD to work but i need help!!! This is my error log:
2012/11/22:17:22:51 Yon Kyu Chung YONKYUCHUNG-PC === Setup started on YONKYUCHUNG-PC by Yon Kyu Chung ===
2012/11/22:17:22:51 Yon Kyu Chung YONKYUCHUNG-PC Launch
2012/11/22:17:22:51 Yon Kyu Chung YONKYUCHUNG-PC CommandLine /url "http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/AutoCAD_2013_English_Win_32_64bit_wi_en-US..." /SN 900-34562569 /PK 001E1 /student /skipEULA /akamai /auth /sid
2012/11/22:17:24:58 Yon Kyu Chung YONKYUCHUNG-PC === Setup ended ===
2012/11/22:17:22:52 Yon Kyu Chung YONKYUCHUNG-PC === Setup started on YONKYUCHUNG-PC by Yon Kyu Chung ===
2012/11/22:17:22:52 Yon Kyu Chung YONKYUCHUNG-PC Launch
2012/11/22:17:23:34 Yon Kyu Chung YONKYUCHUNG-PC Download Play SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/SET...
2012/11/22:17:24:58 Yon Kyu Chung YONKYUCHUNG-PC Download Complete SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/SET...
2012/11/22:17:24:58 Yon Kyu Chung YONKYUCHUNG-PC PageOpen LaunchDialog
2012/11/22:17:25:05 Yon Kyu Chung YONKYUCHUNG-PC Download Play SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/DOT...
2012/11/22:17:27:10 Yon Kyu Chung YONKYUCHUNG-PC Download Complete SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/DOT...
2012/11/22:17:27:10 Yon Kyu Chung YONKYUCHUNG-PC Your computer is using an unsupported version of the Microsoft .NET Framework. The product you are installing requires Microsoft .NET Framework 4.0 or later.
Please update .NET Framework 4.0 and restart your computer before installing your Autodesk product.2012/11/22:17:28:33 Yon Kyu Chung YONKYUCHUNG-PC === Setup ended ===
2012/11/22:17:36:48 Yon Kyu Chung YONKYUCHUNG-PC === Setup started on YONKYUCHUNG-PC by Yon Kyu Chung ===
2012/11/22:17:36:48 Yon Kyu Chung YONKYUCHUNG-PC Launch
2012/11/22:17:36:48 Yon Kyu Chung YONKYUCHUNG-PC CommandLine /url "http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/AutoCAD_2013_English_Win_32_64bit_wi_en-US..." /SN 900-34562569 /PK 001E1 /student /skipEULA /akamai /auth /sid
2012/11/22:17:36:50 Yon Kyu Chung YONKYUCHUNG-PC === Setup ended ===
2012/11/22:17:36:49 Yon Kyu Chung YONKYUCHUNG-PC === Setup started on YONKYUCHUNG-PC by Yon Kyu Chung ===
2012/11/22:17:36:49 Yon Kyu Chung YONKYUCHUNG-PC Launch
2012/11/22:17:36:50 Yon Kyu Chung YONKYUCHUNG-PC Download Skipped SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/SET...
2012/11/22:17:36:50 Yon Kyu Chung YONKYUCHUNG-PC PageOpen LaunchDialog
2012/11/22:17:37:12 Yon Kyu Chung YONKYUCHUNG-PC PageOpen LicenseDialog
2012/11/22:17:37:12 Yon Kyu Chung YONKYUCHUNG-PC PageOpen ProductInfoDialog
2012/11/22:17:37:13 Yon Kyu Chung YONKYUCHUNG-PC PageOpen ProductSelectionDialog2
2012/11/22:17:37:20 Yon Kyu Chung YONKYUCHUNG-PC PageOpen FullProgressDialog
2012/11/22:17:37:20 Yon Kyu Chung YONKYUCHUNG-PC Download Skipped DOTNET4KB2468871 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/DOT...
2012/11/22:17:37:20 Yon Kyu Chung YONKYUCHUNG-PC Installing .NET Framework Runtime 4.0 KB2468871: C:\Autodesk\WI\AutoCAD 2013\3rdParty\NET\4\wcu\dotNetFramework\NDP40-KB2468871-v2-x64.exe /q /norestart
2012/11/22:17:41:23 Yon Kyu Chung YONKYUCHUNG-PC Install .NET Framework Runtime 4.0 KB2468871 Succeeded
2012/11/22:17:41:24 Yon Kyu Chung YONKYUCHUNG-PC Download Play VCREDIST2008SP1X86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/VCR...
2012/11/22:17:41:30 Yon Kyu Chung YONKYUCHUNG-PC Download Complete VCREDIST2008SP1X86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/VCR...
2012/11/22:17:41:30 Yon Kyu Chung YONKYUCHUNG-PC Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): C:\Autodesk\WI\AutoCAD 2013\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe /q
2012/11/22:17:41:34 Yon Kyu Chung YONKYUCHUNG-PC Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Succeeded
2012/11/22:17:41:34 Yon Kyu Chung YONKYUCHUNG-PC Download Play VCREDIST2008SP1X64 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/VCR...
2012/11/22:17:41:41 Yon Kyu Chung YONKYUCHUNG-PC Download Complete VCREDIST2008SP1X64 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/VCR...
2012/11/22:17:41:41 Yon Kyu Chung YONKYUCHUNG-PC Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): C:\Autodesk\WI\AutoCAD 2013\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe /q
2012/11/22:17:41:45 Yon Kyu Chung YONKYUCHUNG-PC Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Succeeded
2012/11/22:17:41:45 Yon Kyu Chung YONKYUCHUNG-PC Download Play VCREDIST2010SP1X86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/VCR...
2012/11/22:17:41:51 Yon Kyu Chung YONKYUCHUNG-PC Download Complete VCREDIST2010SP1X86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/VCR...
2012/11/22:17:41:51 Yon Kyu Chung YONKYUCHUNG-PC Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): C:\Autodesk\WI\AutoCAD 2013\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe /q /norestart /l C:\Users\YONKYU~1\AppData\Local\Temp\vcredist_x86_2010.log
2012/11/22:17:41:55 Yon Kyu Chung YONKYUCHUNG-PC Install Microsoft Visual C++ 2010 SP1 Redistributable (x86) Succeeded
2012/11/22:17:41:56 Yon Kyu Chung YONKYUCHUNG-PC Download Play VCREDIST2010SP1X64 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/VCR...
2012/11/22:17:42:03 Yon Kyu Chung YONKYUCHUNG-PC Download Complete VCREDIST2010SP1X64 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/VCR...
2012/11/22:17:42:03 Yon Kyu Chung YONKYUCHUNG-PC Installing Microsoft Visual C++ 2010 SP1 Redistributable (x64): C:\Autodesk\WI\AutoCAD 2013\3rdParty\x64\VCRedist\2010SP1\vcredist_x64.exe /q /norestart /l C:\Users\YONKYU~1\AppData\Local\Temp\vcredist_x64_2010.log
2012/11/22:17:42:08 Yon Kyu Chung YONKYUCHUNG-PC Install Microsoft Visual C++ 2010 SP1 Redistributable (x64) Succeeded
2012/11/22:17:42:08 Yon Kyu Chung YONKYUCHUNG-PC Download Play DIRECTX http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/DIR...
2012/11/22:17:42:20 Yon Kyu Chung YONKYUCHUNG-PC Download Complete DIRECTX http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/DIR...
2012/11/22:17:42:20 Yon Kyu Chung YONKYUCHUNG-PC Installing DirectX Runtime: C:\Autodesk\WI\AutoCAD 2013\3rdParty\DirectX\DXSETUP.exe /silent
2012/11/22:17:42:34 Yon Kyu Chung YONKYUCHUNG-PC Install DirectX Runtime Succeeded
2012/11/22:17:42:34 Yon Kyu Chung YONKYUCHUNG-PC Installing FaroSDK: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/11/22:17:42:37 Yon Kyu Chung YONKYUCHUNG-PC Install FaroSDK Succeeded
2012/11/22:17:42:38 Yon Kyu Chung YONKYUCHUNG-PC Download Play CM2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/CM2...
2012/11/22:17:43:31 Yon Kyu Chung YONKYUCHUNG-PC Download Complete CM2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/CM2...
2012/11/22:17:43:31 Yon Kyu Chung YONKYUCHUNG-PC Installing Autodesk Material Library 2013: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/11/22:17:43:45 Yon Kyu Chung YONKYUCHUNG-PC Install Autodesk Material Library 2013 Succeeded
2012/11/22:17:43:45 Yon Kyu Chung YONKYUCHUNG-PC Download Play CMILB2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/CMI...
2012/11/22:17:44:46 Yon Kyu Chung YONKYUCHUNG-PC Download Complete CMILB2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/CMI...
2012/11/22:17:44:46 Yon Kyu Chung YONKYUCHUNG-PC Installing Autodesk Material Library 2013 - Low Resolution: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/11/22:17:44:55 Yon Kyu Chung YONKYUCHUNG-PC Install Autodesk Material Library 2013 - Low Resolution Succeeded
2012/11/22:17:44:55 Yon Kyu Chung YONKYUCHUNG-PC Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS="C:\Autodesk\WI\AutoCAD 2013\x64\en-us\Tools\snap\ContentService.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/11/22:17:45:00 Yon Kyu Chung YONKYUCHUNG-PC Install Autodesk Content Service Succeeded
2012/11/22:17:45:00 Yon Kyu Chung YONKYUCHUNG-PC Installing Autodesk Content Service Language Pack: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/11/22:17:45:03 Yon Kyu Chung YONKYUCHUNG-PC Install Autodesk Content Service Language Pack Succeeded
2012/11/22:17:45:03 Yon Kyu Chung YONKYUCHUNG-PC Download Play ACAD http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/ACA...
2012/11/22:17:50:34 Yon Kyu Chung YONKYUCHUNG-PC Download Complete ACAD http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/ACA...
2012/11/22:17:50:34 Yon Kyu Chung YONKYUCHUNG-PC Installing AutoCAD® 2013: TRANSFORMS="C:\Autodesk\WI\AutoCAD 2013\x64\en-us\acad\acad.mst;C:\Users\YONKYU~1\AppData\Local\Temp\_AI513A.tmp\x64\acad\acad-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/11/22:17:52:14 Yon Kyu Chung YONKYUCHUNG-PC Install AutoCAD® 2013 Succeeded
2012/11/22:17:52:15 Yon Kyu Chung YONKYUCHUNG-PC Download Play ACAD_en-us http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/ACA...
2012/11/22:17:53:02 Yon Kyu Chung YONKYUCHUNG-PC Download Complete ACAD_en-us http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/ACA...
2012/11/22:17:53:02 Yon Kyu Chung YONKYUCHUNG-PC Installing AutoCAD® 2013 Language Pack: TRANSFORMS="C:\Users\YONKYU~1\AppData\Local\Temp\_AI513A.tmp\_la2FC6.tmp.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us MUIHIDEARP=1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/11/22:17:53:21 Yon Kyu Chung YONKYUCHUNG-PC Install AutoCAD® 2013 Language Pack Succeeded
2012/11/22:17:53:21 Yon Kyu Chung YONKYUCHUNG-PC Download Skipped ACAD_PSPACK http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/ACA...
2012/11/22:17:53:21 Yon Kyu Chung YONKYUCHUNG-PC Installing AutoCAD® 2013 Product Specific Pack: INSTALLSHORTCUTS=0 ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/11/22:17:53:50 Yon Kyu Chung YONKYUCHUNG-PC Install AutoCAD® 2013 Product Specific Pack Succeeded
2012/11/22:17:53:50 Yon Kyu Chung YONKYUCHUNG-PC Installing Autodesk Cloud sync: ADLANGUAGE=en-us ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/11/22:17:53:52 Yon Kyu Chung YONKYUCHUNG-PC Install Autodesk Cloud sync Succeeded
2012/11/22:17:53:53 Yon Kyu Chung YONKYUCHUNG-PC Download Play VCREDIST2005SP1ATLX86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/VCR...
2012/11/22:17:53:57 Yon Kyu Chung YONKYUCHUNG-PC Download Complete VCREDIST2005SP1ATLX86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/VCR...
2012/11/22:17:53:57 Yon Kyu Chung YONKYUCHUNG-PC Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): C:\Autodesk\WI\AutoCAD 2013\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\YONKYU~1\AppData\Local\Temp\vcredist_x86_2005.log"" "
2012/11/22:17:54:04 Yon Kyu Chung YONKYUCHUNG-PC Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Succeeded
2012/11/22:17:54:05 Yon Kyu Chung YONKYUCHUNG-PC Download Play VCREDIST2005SP1ATLX64 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/VCR...
2012/11/22:17:54:19 Yon Kyu Chung YONKYUCHUNG-PC Download Complete VCREDIST2005SP1ATLX64 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/VCR...
2012/11/22:17:54:19 Yon Kyu Chung YONKYUCHUNG-PC Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64): C:\Autodesk\WI\AutoCAD 2013\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\YONKYU~1\AppData\Local\Temp\vcredist_x64_2005.log"" "
2012/11/22:17:54:25 Yon Kyu Chung YONKYUCHUNG-PC Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) Succeeded
2012/11/22:17:54:25 Yon Kyu Chung YONKYUCHUNG-PC Download Play InventorFusion http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/Inv...
2012/11/22:17:57:58 Yon Kyu Chung YONKYUCHUNG-PC Download Complete InventorFusion http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/Inv...
2012/11/22:17:57:58 Yon Kyu Chung YONKYUCHUNG-PC Installing Autodesk® Inventor® Fusion 2013: TRANSFORMS="C:\Users\YONKYU~1\AppData\Local\Temp\_AI513A.tmp\x64\InventorFusion\InventorFusion-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" INSTALLDIR="C:\Program Files\Autodesk\Inventor Fusion 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/11/22:18:01:58 Yon Kyu Chung YONKYUCHUNG-PC Install Autodesk® Inventor® Fusion 2013 Succeeded
2012/11/22:18:01:59 Yon Kyu Chung YONKYUCHUNG-PC Download Play ACFUSION http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/ACF...
2012/11/22:18:02:04 Yon Kyu Chung YONKYUCHUNG-PC Download Complete ACFUSION http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/ACF...
2012/11/22:18:02:04 Yon Kyu Chung YONKYUCHUNG-PC Installing Autodesk Inventor Fusion plug-in for AutoCAD 2013: TRANSFORMS="C:\Autodesk\WI\AutoCAD 2013\x64\en-us\AcFusion\AcFusion.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/11/22:18:02:05 Yon Kyu Chung YONKYUCHUNG-PC Install Autodesk Inventor Fusion plug-in for AutoCAD 2013 Succeeded
2012/11/22:18:02:06 Yon Kyu Chung YONKYUCHUNG-PC Download Play ACFUSION_en-us http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/ACF...
2012/11/22:18:02:10 Yon Kyu Chung YONKYUCHUNG-PC Download Complete ACFUSION_en-us http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/ACF...
2012/11/22:18:02:10 Yon Kyu Chung YONKYUCHUNG-PC Installing Inventor Fusion plug-in for AutoCAD 2013 Language Pack: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/11/22:18:02:11 Yon Kyu Chung YONKYUCHUNG-PC Install Inventor Fusion plug-in for AutoCAD 2013 Language Pack Succeeded
2012/11/22:18:02:13 Yon Kyu Chung YONKYUCHUNG-PC PageOpen InstallCompleteDialog
2012/11/22:18:03:50 Yon Kyu Chung YONKYUCHUNG-PC === Setup ended ===
2012/11/23:21:34:39 Yon Kyu Chung YONKYUCHUNG-PC === Setup started on YONKYUCHUNG-PC by Yon Kyu Chung ===
2012/11/23:21:34:39 Yon Kyu Chung YONKYUCHUNG-PC Launch
2012/11/23:21:34:39 Yon Kyu Chung YONKYUCHUNG-PC CommandLine /url "http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/AutoCAD_2013_English_Win_32_64bit_wi_en-US..." /SN 900-34562569 /PK 001E1 /student /skipEULA /akamai /auth /sid
2012/11/23:21:34:43 Yon Kyu Chung YONKYUCHUNG-PC === Setup ended ===
2012/11/23:21:34:40 Yon Kyu Chung YONKYUCHUNG-PC === Setup started on YONKYUCHUNG-PC by Yon Kyu Chung ===
2012/11/23:21:34:40 Yon Kyu Chung YONKYUCHUNG-PC Launch
2012/11/23:21:34:42 Yon Kyu Chung YONKYUCHUNG-PC Download Skipped SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/SET...
2012/11/23:21:34:43 Yon Kyu Chung YONKYUCHUNG-PC PageOpen LaunchDialog
2012/11/23:21:35:03 Yon Kyu Chung YONKYUCHUNG-PC PageOpen LicenseDialog
2012/11/23:21:35:03 Yon Kyu Chung YONKYUCHUNG-PC PageOpen ProductInfoDialog
2012/11/23:21:35:03 Yon Kyu Chung YONKYUCHUNG-PC PageOpen ProductSelectionDialog2
2012/11/23:21:35:07 Yon Kyu Chung YONKYUCHUNG-PC PageOpen FullProgressDialog
2012/11/23:21:35:07 Yon Kyu Chung YONKYUCHUNG-PC Download Skipped DIRECTX http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/DIR...
2012/11/23:21:35:07 Yon Kyu Chung YONKYUCHUNG-PC Installing DirectX Runtime: C:\Autodesk\WI\AutoCAD 2013\3rdParty\DirectX\DXSETUP.exe /silent
2012/11/23:21:35:27 Yon Kyu Chung YONKYUCHUNG-PC Install DirectX Runtime Succeeded
2012/11/23:21:35:27 Yon Kyu Chung YONKYUCHUNG-PC Installing FaroSDK: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/11/23:21:35:33 Yon Kyu Chung YONKYUCHUNG-PC Install FaroSDK Succeeded
2012/11/23:21:35:33 Yon Kyu Chung YONKYUCHUNG-PC Download Skipped CM2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/CM2...
2012/11/23:21:35:33 Yon Kyu Chung YONKYUCHUNG-PC Installing Autodesk Material Library 2013: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/11/23:21:35:46 Yon Kyu Chung YONKYUCHUNG-PC Install Autodesk Material Library 2013 Succeeded
2012/11/23:21:35:46 Yon Kyu Chung YONKYUCHUNG-PC Download Skipped CMILB2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/CMI...
2012/11/23:21:35:46 Yon Kyu Chung YONKYUCHUNG-PC Installing Autodesk Material Library 2013 - Low Resolution: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/11/23:21:36:07 Yon Kyu Chung YONKYUCHUNG-PC Install Autodesk Material Library 2013 - Low Resolution Succeeded
2012/11/23:21:36:07 Yon Kyu Chung YONKYUCHUNG-PC Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS="C:\Autodesk\WI\AutoCAD 2013\x64\en-us\Tools\snap\ContentService.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/11/23:21:36:15 Yon Kyu Chung YONKYUCHUNG-PC Install Autodesk Content Service Succeeded
2012/11/23:21:36:15 Yon Kyu Chung YONKYUCHUNG-PC Installing Autodesk Content Service Language Pack: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/11/23:21:36:19 Yon Kyu Chung YONKYUCHUNG-PC Install Autodesk Content Service Language Pack Succeeded
2012/11/23:21:36:19 Yon Kyu Chung YONKYUCHUNG-PC Download Skipped ACAD http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/ACA...
2012/11/23:21:36:20 Yon Kyu Chung YONKYUCHUNG-PC Installing AutoCAD® 2013: TRANSFORMS="C:\Autodesk\WI\AutoCAD 2013\x64\en-us\acad\acad.mst;C:\Users\YONKYU~1\AppData\Local\Temp\_AIF6AD.tmp\x64\acad\acad-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/11/23:21:36:34 Yon Kyu Chung YONKYUCHUNG-PC Install AutoCAD® 2013 Failed Installation aborted, Result=1603
2012/11/23:21:36:37 Yon Kyu Chung YONKYUCHUNG-PC Rollback Autodesk Content Service Language Pack Succeeded
2012/11/23:21:36:40 Yon Kyu Chung YONKYUCHUNG-PC Rollback Autodesk Content Service Succeeded
2012/11/23:21:36:52 Yon Kyu Chung YONKYUCHUNG-PC Rollback Autodesk Material Library 2013 - Low Resolution Succeeded
2012/11/23:21:37:10 Yon Kyu Chung YONKYUCHUNG-PC Rollback Autodesk Material Library 2013 Succeeded
2012/11/23:21:37:11 Yon Kyu Chung YONKYUCHUNG-PC Rollback FaroSDK Succeeded
2012/11/23:21:37:11 Yon Kyu Chung YONKYUCHUNG-PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2012/11/23:21:37:11 Yon Kyu Chung YONKYUCHUNG-PC PageOpen InstallCompleteDialog
2012/11/23:21:44:12 Yon Kyu Chung YONKYUCHUNG-PC === Setup ended ===
2012/11/23:21:50:47 Yon Kyu Chung YONKYUCHUNG-PC === Setup started on YONKYUCHUNG-PC by Yon Kyu Chung ===
2012/11/23:21:50:47 Yon Kyu Chung YONKYUCHUNG-PC Launch
2012/11/23:21:50:47 Yon Kyu Chung YONKYUCHUNG-PC CommandLine /url "http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/AutoCAD_2013_English_Win_32_64bit_wi_en-US..." /SN 900-34562569 /PK 001E1 /student /skipEULA /akamai /auth /sid
2012/11/23:21:50:49 Yon Kyu Chung YONKYUCHUNG-PC === Setup ended ===
2012/11/23:21:50:48 Yon Kyu Chung YONKYUCHUNG-PC === Setup started on YONKYUCHUNG-PC by Yon Kyu Chung ===
2012/11/23:21:50:48 Yon Kyu Chung YONKYUCHUNG-PC Launch
2012/11/23:21:50:49 Yon Kyu Chung YONKYUCHUNG-PC Download Skipped SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/SET...
2012/11/23:21:50:49 Yon Kyu Chung YONKYUCHUNG-PC PageOpen LaunchDialog
2012/11/23:21:51:08 Yon Kyu Chung YONKYUCHUNG-PC PageOpen LicenseDialog
2012/11/23:21:51:08 Yon Kyu Chung YONKYUCHUNG-PC PageOpen ProductInfoDialog
2012/11/23:21:51:08 Yon Kyu Chung YONKYUCHUNG-PC PageOpen ProductSelectionDialog2
2012/11/23:21:51:13 Yon Kyu Chung YONKYUCHUNG-PC PageOpen FullProgressDialog
2012/11/23:21:51:14 Yon Kyu Chung YONKYUCHUNG-PC Download Skipped DIRECTX http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/DIR...
2012/11/23:21:51:14 Yon Kyu Chung YONKYUCHUNG-PC Installing DirectX Runtime: C:\Autodesk\WI\AutoCAD 2013\3rdParty\DirectX\DXSETUP.exe /silent
2012/11/23:21:51:38 Yon Kyu Chung YONKYUCHUNG-PC Install DirectX Runtime Succeeded
2012/11/23:21:51:38 Yon Kyu Chung YONKYUCHUNG-PC Installing FaroSDK: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/11/23:21:51:41 Yon Kyu Chung YONKYUCHUNG-PC Install FaroSDK Succeeded
2012/11/23:21:51:44 Yon Kyu Chung YONKYUCHUNG-PC Download Skipped CM2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/CM2...
2012/11/23:21:51:44 Yon Kyu Chung YONKYUCHUNG-PC Installing Autodesk Material Library 2013: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/11/23:21:51:58 Yon Kyu Chung YONKYUCHUNG-PC Install Autodesk Material Library 2013 Succeeded
2012/11/23:21:51:58 Yon Kyu Chung YONKYUCHUNG-PC Download Skipped CMILB2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/CMI...
2012/11/23:21:51:58 Yon Kyu Chung YONKYUCHUNG-PC Installing Autodesk Material Library 2013 - Low Resolution: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/11/23:21:52:08 Yon Kyu Chung YONKYUCHUNG-PC Install Autodesk Material Library 2013 - Low Resolution Succeeded
2012/11/23:21:52:08 Yon Kyu Chung YONKYUCHUNG-PC Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS="C:\Autodesk\WI\AutoCAD 2013\x64\en-us\Tools\snap\ContentService.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/11/23:21:52:14 Yon Kyu Chung YONKYUCHUNG-PC Install Autodesk Content Service Succeeded
2012/11/23:21:52:14 Yon Kyu Chung YONKYUCHUNG-PC Installing Autodesk Content Service Language Pack: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/11/23:21:52:17 Yon Kyu Chung YONKYUCHUNG-PC Install Autodesk Content Service Language Pack Succeeded
2012/11/23:21:52:17 Yon Kyu Chung YONKYUCHUNG-PC Download Skipped ACAD http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/ACA...
2012/11/23:21:52:18 Yon Kyu Chung YONKYUCHUNG-PC Installing AutoCAD® 2013: TRANSFORMS="C:\Autodesk\WI\AutoCAD 2013\x64\en-us\acad\acad.mst;C:\Users\YONKYU~1\AppData\Local\Temp\_AIBBEF.tmp\x64\acad\acad-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/11/23:21:52:28 Yon Kyu Chung YONKYUCHUNG-PC Install AutoCAD® 2013 Failed Installation aborted, Result=1603
2012/11/23:21:52:30 Yon Kyu Chung YONKYUCHUNG-PC Rollback Autodesk Content Service Language Pack Succeeded
2012/11/23:21:52:32 Yon Kyu Chung YONKYUCHUNG-PC Rollback Autodesk Content Service Succeeded
2012/11/23:21:52:43 Yon Kyu Chung YONKYUCHUNG-PC Rollback Autodesk Material Library 2013 - Low Resolution Succeeded
2012/11/23:21:53:00 Yon Kyu Chung YONKYUCHUNG-PC Rollback Autodesk Material Library 2013 Succeeded
2012/11/23:21:53:00 Yon Kyu Chung YONKYUCHUNG-PC Rollback FaroSDK Succeeded
2012/11/23:21:53:00 Yon Kyu Chung YONKYUCHUNG-PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2012/11/23:21:53:01 Yon Kyu Chung YONKYUCHUNG-PC PageOpen InstallCompleteDialog
2012/11/23:22:01:34 Yon Kyu Chung YONKYUCHUNG-PC === Setup ended ===
2012/11/23:22:27:29 Yon Kyu Chung YONKYUCHUNG-PC === Setup started on YONKYUCHUNG-PC by Yon Kyu Chung ===
2012/11/23:22:27:29 Yon Kyu Chung YONKYUCHUNG-PC Launch
2012/11/23:22:27:29 Yon Kyu Chung YONKYUCHUNG-PC CommandLine /url "http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/AutoCAD_2013_English_Win_32_64bit_wi_en-US..." /SN 900-34562569 /PK 001E1 /student /skipEULA /akamai /auth /sid
2012/11/23:22:27:32 Yon Kyu Chung YONKYUCHUNG-PC === Setup ended ===
2012/11/23:22:27:30 Yon Kyu Chung YONKYUCHUNG-PC === Setup started on YONKYUCHUNG-PC by Yon Kyu Chung ===
2012/11/23:22:27:30 Yon Kyu Chung YONKYUCHUNG-PC Launch
2012/11/23:22:27:32 Yon Kyu Chung YONKYUCHUNG-PC Download Skipped SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/SET...
2012/11/23:22:27:32 Yon Kyu Chung YONKYUCHUNG-PC PageOpen LaunchDialog
2012/11/23:22:27:51 Yon Kyu Chung YONKYUCHUNG-PC PageOpen LicenseDialog
2012/11/23:22:27:51 Yon Kyu Chung YONKYUCHUNG-PC PageOpen ProductInfoDialog
2012/11/23:22:27:51 Yon Kyu Chung YONKYUCHUNG-PC PageOpen ProductSelectionDialog2
2012/11/23:22:27:57 Yon Kyu Chung YONKYUCHUNG-PC PageOpen FullProgressDialog
2012/11/23:22:27:57 Yon Kyu Chung YONKYUCHUNG-PC Download Skipped DIRECTX http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/DIR...
2012/11/23:22:27:57 Yon Kyu Chung YONKYUCHUNG-PC Installing DirectX Runtime: C:\Autodesk\WI\AutoCAD 2013\3rdParty\DirectX\DXSETUP.exe /silent
2012/11/23:22:28:14 Yon Kyu Chung YONKYUCHUNG-PC Install DirectX Runtime Succeeded
2012/11/23:22:28:14 Yon Kyu Chung YONKYUCHUNG-PC Installing FaroSDK: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/11/23:22:28:18 Yon Kyu Chung YONKYUCHUNG-PC Install FaroSDK Succeeded
2012/11/23:22:28:18 Yon Kyu Chung YONKYUCHUNG-PC Download Skipped CM2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/CM2...
2012/11/23:22:28:18 Yon Kyu Chung YONKYUCHUNG-PC Installing Autodesk Material Library 2013: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/11/23:22:28:33 Yon Kyu Chung YONKYUCHUNG-PC Install Autodesk Material Library 2013 Succeeded
2012/11/23:22:28:33 Yon Kyu Chung YONKYUCHUNG-PC Download Skipped CMILB2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/CMI...
2012/11/23:22:28:33 Yon Kyu Chung YONKYUCHUNG-PC Installing Autodesk Material Library 2013 - Low Resolution: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/11/23:22:28:44 Yon Kyu Chung YONKYUCHUNG-PC Install Autodesk Material Library 2013 - Low Resolution Succeeded
2012/11/23:22:28:44 Yon Kyu Chung YONKYUCHUNG-PC Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS="C:\Autodesk\WI\AutoCAD 2013\x64\en-us\Tools\snap\ContentService.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/11/23:22:28:50 Yon Kyu Chung YONKYUCHUNG-PC Install Autodesk Content Service Succeeded
2012/11/23:22:28:50 Yon Kyu Chung YONKYUCHUNG-PC Installing Autodesk Content Service Language Pack: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/11/23:22:28:53 Yon Kyu Chung YONKYUCHUNG-PC Install Autodesk Content Service Language Pack Succeeded
2012/11/23:22:28:53 Yon Kyu Chung YONKYUCHUNG-PC Download Skipped ACAD http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/ACA...
2012/11/23:22:28:53 Yon Kyu Chung YONKYUCHUNG-PC Installing AutoCAD® 2013: TRANSFORMS="C:\Autodesk\WI\AutoCAD 2013\x64\en-us\acad\acad.mst;C:\Users\YONKYU~1\AppData\Local\Temp\_AI2FF5.tmp\x64\acad\acad-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/11/23:22:29:05 Yon Kyu Chung YONKYUCHUNG-PC Install AutoCAD® 2013 Failed Installation aborted, Result=1603
2012/11/23:22:29:07 Yon Kyu Chung YONKYUCHUNG-PC Rollback Autodesk Content Service Language Pack Succeeded
2012/11/23:22:29:09 Yon Kyu Chung YONKYUCHUNG-PC Rollback Autodesk Content Service Succeeded
2012/11/23:22:29:20 Yon Kyu Chung YONKYUCHUNG-PC Rollback Autodesk Material Library 2013 - Low Resolution Succeeded
2012/11/23:22:29:36 Yon Kyu Chung YONKYUCHUNG-PC Rollback Autodesk Material Library 2013 Succeeded
2012/11/23:22:29:37 Yon Kyu Chung YONKYUCHUNG-PC Rollback FaroSDK Succeeded
2012/11/23:22:29:37 Yon Kyu Chung YONKYUCHUNG-PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2012/11/23:22:29:38 Yon Kyu Chung YONKYUCHUNG-PC PageOpen InstallCompleteDialog
2012/11/23:22:31:40 Yon Kyu Chung YONKYUCHUNG-PC === Setup ended ===
2012/11/23:23:06:59 Yon Kyu Chung YONKYUCHUNG-PC === Setup started on YONKYUCHUNG-PC by Yon Kyu Chung ===
2012/11/23:23:06:59 Yon Kyu Chung YONKYUCHUNG-PC Launch
2012/11/23:23:06:59 Yon Kyu Chung YONKYUCHUNG-PC CommandLine /url "http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/AutoCAD_2013_English_Win_32_64bit_wi_en-US..." /SN 900-34562569 /PK 001E1 /student /skipEULA /akamai /auth /sid
2012/11/23:23:07:01 Yon Kyu Chung YONKYUCHUNG-PC === Setup ended ===
2012/11/23:23:07:00 Yon Kyu Chung YONKYUCHUNG-PC === Setup started on YONKYUCHUNG-PC by Yon Kyu Chung ===
2012/11/23:23:07:00 Yon Kyu Chung YONKYUCHUNG-PC Launch
2012/11/23:23:07:00 Yon Kyu Chung YONKYUCHUNG-PC Download Skipped SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/SET...
2012/11/23:23:07:01 Yon Kyu Chung YONKYUCHUNG-PC PageOpen LaunchDialog
2012/11/23:23:07:19 Yon Kyu Chung YONKYUCHUNG-PC PageOpen LicenseDialog
2012/11/23:23:07:19 Yon Kyu Chung YONKYUCHUNG-PC PageOpen ProductInfoDialog
2012/11/23:23:07:19 Yon Kyu Chung YONKYUCHUNG-PC PageOpen ProductSelectionDialog2
2012/11/23:23:07:37 Yon Kyu Chung YONKYUCHUNG-PC PageOpen FullProgressDialog
2012/11/23:23:07:38 Yon Kyu Chung YONKYUCHUNG-PC Download Skipped DIRECTX http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/DIR...
2012/11/23:23:07:38 Yon Kyu Chung YONKYUCHUNG-PC Installing DirectX Runtime: C:\Autodesk\WI\AutoCAD 2013\3rdParty\DirectX\DXSETUP.exe /silent
2012/11/23:23:07:54 Yon Kyu Chung YONKYUCHUNG-PC Install DirectX Runtime Succeeded
2012/11/23:23:07:54 Yon Kyu Chung YONKYUCHUNG-PC Installing FaroSDK: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/11/23:23:07:59 Yon Kyu Chung YONKYUCHUNG-PC Install FaroSDK Succeeded
2012/11/23:23:07:59 Yon Kyu Chung YONKYUCHUNG-PC Download Skipped CM2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/CM2...
2012/11/23:23:07:59 Yon Kyu Chung YONKYUCHUNG-PC Installing Autodesk Material Library 2013: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/11/23:23:08:13 Yon Kyu Chung YONKYUCHUNG-PC Install Autodesk Material Library 2013 Succeeded
2012/11/23:23:08:13 Yon Kyu Chung YONKYUCHUNG-PC Download Skipped CMILB2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/CMI...
2012/11/23:23:08:13 Yon Kyu Chung YONKYUCHUNG-PC Installing Autodesk Material Library 2013 - Low Resolution: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/11/23:23:08:23 Yon Kyu Chung YONKYUCHUNG-PC Install Autodesk Material Library 2013 - Low Resolution Succeeded
2012/11/23:23:08:23 Yon Kyu Chung YONKYUCHUNG-PC Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS="C:\Autodesk\WI\AutoCAD 2013\x64\en-us\Tools\snap\ContentService.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/11/23:23:08:28 Yon Kyu Chung YONKYUCHUNG-PC Install Autodesk Content Service Succeeded
2012/11/23:23:08:28 Yon Kyu Chung YONKYUCHUNG-PC Installing Autodesk Content Service Language Pack: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/11/23:23:08:31 Yon Kyu Chung YONKYUCHUNG-PC Install Autodesk Content Service Language Pack Succeeded
2012/11/23:23:08:31 Yon Kyu Chung YONKYUCHUNG-PC Download Skipped ACAD http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/ACA...
2012/11/23:23:08:31 Yon Kyu Chung YONKYUCHUNG-PC Installing AutoCAD® 2013: TRANSFORMS="C:\Autodesk\WI\AutoCAD 2013\x64\en-us\acad\acad.mst;C:\Users\YONKYU~1\AppData\Local\Temp\_AI57D0.tmp\x64\acad\acad-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/11/23:23:08:42 Yon Kyu Chung YONKYUCHUNG-PC Install AutoCAD® 2013 Failed Installation aborted, Result=1603
2012/11/23:23:08:44 Yon Kyu Chung YONKYUCHUNG-PC Rollback Autodesk Content Service Language Pack Succeeded
2012/11/23:23:08:46 Yon Kyu Chung YONKYUCHUNG-PC Rollback Autodesk Content Service Succeeded
2012/11/23:23:08:57 Yon Kyu Chung YONKYUCHUNG-PC Rollback Autodesk Material Library 2013 - Low Resolution Succeeded
2012/11/23:23:09:13 Yon Kyu Chung YONKYUCHUNG-PC Rollback Autodesk Material Library 2013 Succeeded
2012/11/23:23:09:14 Yon Kyu Chung YONKYUCHUNG-PC Rollback FaroSDK Succeeded
2012/11/23:23:09:14 Yon Kyu Chung YONKYUCHUNG-PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2012/11/23:23:09:15 Yon Kyu Chung YONKYUCHUNG-PC PageOpen InstallCompleteDialog
2012/11/23:23:12:48 Yon Kyu Chung YONKYUCHUNG-PC === Setup ended ===
2012/11/24:10:07:34 Yon Kyu Chung YONKYUCHUNG-PC === Setup started on YONKYUCHUNG-PC by Yon Kyu Chung ===
2012/11/24:10:07:34 Yon Kyu Chung YONKYUCHUNG-PC Launch
2012/11/24:10:07:34 Yon Kyu Chung YONKYUCHUNG-PC CommandLine /url "http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/AutoCAD_2013_English_Win_32_64bit_wi_en-US..." /SN 900-34562569 /PK 001E1 /student /skipEULA /akamai /auth /sid
2012/11/24:10:07:36 Yon Kyu Chung YONKYUCHUNG-PC === Setup ended ===
2012/11/24:10:07:35 Yon Kyu Chung YONKYUCHUNG-PC === Setup started on YONKYUCHUNG-PC by Yon Kyu Chung ===
2012/11/24:10:07:35 Yon Kyu Chung YONKYUCHUNG-PC Launch
2012/11/24:10:07:35 Yon Kyu Chung YONKYUCHUNG-PC Download Skipped SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/SET...
2012/11/24:10:07:36 Yon Kyu Chung YONKYUCHUNG-PC PageOpen LaunchDialog
2012/11/24:10:14:44 Yon Kyu Chung YONKYUCHUNG-PC PageOpen LicenseDialog
2012/11/24:10:14:44 Yon Kyu Chung YONKYUCHUNG-PC PageOpen ProductInfoDialog
2012/11/24:10:14:44 Yon Kyu Chung YONKYUCHUNG-PC PageOpen ProductSelectionDialog2
2012/11/24:10:14:48 Yon Kyu Chung YONKYUCHUNG-PC PageOpen FullProgressDialog
2012/11/24:10:14:48 Yon Kyu Chung YONKYUCHUNG-PC Download Skipped DIRECTX http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/DIR...
2012/11/24:10:14:48 Yon Kyu Chung YONKYUCHUNG-PC Installing DirectX Runtime: C:\Autodesk\WI\AutoCAD 2013\3rdParty\DirectX\DXSETUP.exe /silent
2012/11/24:10:15:04 Yon Kyu Chung YONKYUCHUNG-PC Install DirectX Runtime Succeeded
2012/11/24:10:15:04 Yon Kyu Chung YONKYUCHUNG-PC Installing FaroSDK: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/11/24:10:15:07 Yon Kyu Chung YONKYUCHUNG-PC Install FaroSDK Succeeded
2012/11/24:10:15:08 Yon Kyu Chung YONKYUCHUNG-PC Download Skipped CM2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/CM2...
2012/11/24:10:15:08 Yon Kyu Chung YONKYUCHUNG-PC Installing Autodesk Material Library 2013: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/11/24:10:15:21 Yon Kyu Chung YONKYUCHUNG-PC Install Autodesk Material Library 2013 Succeeded
2012/11/24:10:15:22 Yon Kyu Chung YONKYUCHUNG-PC Download Skipped CMILB2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/CMI...
2012/11/24:10:15:22 Yon Kyu Chung YONKYUCHUNG-PC Installing Autodesk Material Library 2013 - Low Resolution: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/11/24:10:15:31 Yon Kyu Chung YONKYUCHUNG-PC Install Autodesk Material Library 2013 - Low Resolution Succeeded
2012/11/24:10:15:31 Yon Kyu Chung YONKYUCHUNG-PC Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS="C:\Autodesk\WI\AutoCAD 2013\x64\en-us\Tools\snap\ContentService.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/11/24:10:15:38 Yon Kyu Chung YONKYUCHUNG-PC Install Autodesk Content Service Succeeded
2012/11/24:10:15:38 Yon Kyu Chung YONKYUCHUNG-PC Installing Autodesk Content Service Language Pack: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/11/24:10:15:40 Yon Kyu Chung YONKYUCHUNG-PC Install Autodesk Content Service Language Pack Succeeded
2012/11/24:10:15:40 Yon Kyu Chung YONKYUCHUNG-PC Download Skipped ACAD http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/ACA...
2012/11/24:10:15:41 Yon Kyu Chung YONKYUCHUNG-PC Installing AutoCAD® 2013: TRANSFORMS="C:\Autodesk\WI\AutoCAD 2013\x64\en-us\acad\acad.mst;C:\Users\YONKYU~1\AppData\Local\Temp\_AI2BE0.tmp\x64\acad\acad-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/11/24:10:15:51 Yon Kyu Chung YONKYUCHUNG-PC Install AutoCAD® 2013 Failed Installation aborted, Result=1603
2012/11/24:10:15:53 Yon Kyu Chung YONKYUCHUNG-PC Rollback Autodesk Content Service Language Pack Succeeded
2012/11/24:10:15:55 Yon Kyu Chung YONKYUCHUNG-PC Rollback Autodesk Content Service Succeeded
2012/11/24:10:16:06 Yon Kyu Chung YONKYUCHUNG-PC Rollback Autodesk Material Library 2013 - Low Resolution Succeeded
2012/11/24:10:16:21 Yon Kyu Chung YONKYUCHUNG-PC Rollback Autodesk Material Library 2013 Succeeded
2012/11/24:10:16:22 Yon Kyu Chung YONKYUCHUNG-PC Rollback FaroSDK Succeeded
2012/11/24:10:16:22 Yon Kyu Chung YONKYUCHUNG-PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2012/11/24:10:16:23 Yon Kyu Chung YONKYUCHUNG-PC PageOpen InstallCompleteDialog
2012/11/24:10:17:46 Yon Kyu Chung YONKYUCHUNG-PC === Setup ended ===
2012/11/24:10:25:54 Yon Kyu Chung YONKYUCHUNG-PC === Setup started on YONKYUCHUNG-PC by Yon Kyu Chung ===
2012/11/24:10:25:54 Yon Kyu Chung YONKYUCHUNG-PC Launch
2012/11/24:10:25:54 Yon Kyu Chung YONKYUCHUNG-PC CommandLine /url "http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/AutoCAD_2013_English_Win_32_64bit_wi_en-US..." /SN 900-34562569 /PK 001E1 /student /skipEULA /akamai /auth /sid
2012/11/24:10:25:57 Yon Kyu Chung YONKYUCHUNG-PC === Setup ended ===
2012/11/24:10:25:56 Yon Kyu Chung YONKYUCHUNG-PC === Setup started on YONKYUCHUNG-PC by Yon Kyu Chung ===
2012/11/24:10:25:56 Yon Kyu Chung YONKYUCHUNG-PC Launch
2012/11/24:10:25:56 Yon Kyu Chung YONKYUCHUNG-PC Download Skipped SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/SET...
2012/11/24:10:25:56 Yon Kyu Chung YONKYUCHUNG-PC PageOpen LaunchDialog
2012/11/24:10:26:12 Yon Kyu Chung YONKYUCHUNG-PC PageOpen LicenseDialog
2012/11/24:10:26:12 Yon Kyu Chung YONKYUCHUNG-PC PageOpen ProductInfoDialog
2012/11/24:10:26:12 Yon Kyu Chung YONKYUCHUNG-PC PageOpen ProductSelectionDialog2
2012/11/24:10:26:19 Yon Kyu Chung YONKYUCHUNG-PC PageOpen FullProgressDialog
2012/11/24:10:26:19 Yon Kyu Chung YONKYUCHUNG-PC Download Skipped VCREDIST2008SP1X86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/VCR...
2012/11/24:10:26:19 Yon Kyu Chung YONKYUCHUNG-PC Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): C:\Autodesk\WI\AutoCAD 2013\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe /q
2012/11/24:10:26:23 Yon Kyu Chung YONKYUCHUNG-PC Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Succeeded
2012/11/24:10:26:23 Yon Kyu Chung YONKYUCHUNG-PC Download Skipped VCREDIST2008SP1X64 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/VCR...
2012/11/24:10:26:23 Yon Kyu Chung YONKYUCHUNG-PC Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): C:\Autodesk\WI\AutoCAD 2013\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe /q
2012/11/24:10:26:27 Yon Kyu Chung YONKYUCHUNG-PC Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Succeeded
2012/11/24:10:26:27 Yon Kyu Chung YONKYUCHUNG-PC Download Skipped VCREDIST2010SP1X86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/VCR...
2012/11/24:10:26:27 Yon Kyu Chung YONKYUCHUNG-PC Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): C:\Autodesk\WI\AutoCAD 2013\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe /q /norestart /l C:\Users\YONKYU~1\AppData\Local\Temp\vcredist_x86_2010.log
2012/11/24:10:26:32 Yon Kyu Chung YONKYUCHUNG-PC Install Microsoft Visual C++ 2010 SP1 Redistributable (x86) Succeeded
2012/11/24:10:26:32 Yon Kyu Chung YONKYUCHUNG-PC Download Skipped VCREDIST2010SP1X64 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/VCR...
2012/11/24:10:26:32 Yon Kyu Chung YONKYUCHUNG-PC Installing Microsoft Visual C++ 2010 SP1 Redistributable (x64): C:\Autodesk\WI\AutoCAD 2013\3rdParty\x64\VCRedist\2010SP1\vcredist_x64.exe /q /norestart /l C:\Users\YONKYU~1\AppData\Local\Temp\vcredist_x64_2010.log
2012/11/24:10:26:37 Yon Kyu Chung YONKYUCHUNG-PC Install Microsoft Visual C++ 2010 SP1 Redistributable (x64) Succeeded
2012/11/24:10:26:38 Yon Kyu Chung YONKYUCHUNG-PC Download Skipped DIRECTX http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/DIR...
2012/11/24:10:26:38 Yon Kyu Chung YONKYUCHUNG-PC Installing DirectX Runtime: C:\Autodesk\WI\AutoCAD 2013\3rdParty\DirectX\DXSETUP.exe /silent
2012/11/24:10:26:52 Yon Kyu Chung YONKYUCHUNG-PC Install DirectX Runtime Succeeded
2012/11/24:10:26:52 Yon Kyu Chung YONKYUCHUNG-PC Installing FaroSDK: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/11/24:10:26:54 Yon Kyu Chung YONKYUCHUNG-PC Install FaroSDK Succeeded
2012/11/24:10:26:55 Yon Kyu Chung YONKYUCHUNG-PC Download Skipped CM2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/CM2...
2012/11/24:10:26:55 Yon Kyu Chung YONKYUCHUNG-PC Installing Autodesk Material Library 2013: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/11/24:10:27:09 Yon Kyu Chung YONKYUCHUNG-PC Install Autodesk Material Library 2013 Succeeded
2012/11/24:10:27:09 Yon Kyu Chung YONKYUCHUNG-PC Download Skipped CMILB2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/CMI...
2012/11/24:10:27:09 Yon Kyu Chung YONKYUCHUNG-PC Installing Autodesk Material Library 2013 - Low Resolution: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/11/24:10:27:19 Yon Kyu Chung YONKYUCHUNG-PC Install Autodesk Material Library 2013 - Low Resolution Succeeded
2012/11/24:10:27:19 Yon Kyu Chung YONKYUCHUNG-PC Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS="C:\Autodesk\WI\AutoCAD 2013\x64\en-us\Tools\snap\ContentService.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/11/24:10:27:24 Yon Kyu Chung YONKYUCHUNG-PC Install Autodesk Content Service Succeeded
2012/11/24:10:27:24 Yon Kyu Chung YONKYUCHUNG-PC Installing Autodesk Content Service Language Pack: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/11/24:10:27:27 Yon Kyu Chung YONKYUCHUNG-PC Install Autodesk Content Service Language Pack Succeeded
2012/11/24:10:27:27 Yon Kyu Chung YONKYUCHUNG-PC Download Skipped ACAD http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/ACA...
2012/11/24:10:27:28 Yon Kyu Chung YONKYUCHUNG-PC Installing AutoCAD® 2013: TRANSFORMS="C:\Autodesk\WI\AutoCAD 2013\x64\en-us\acad\acad.mst;C:\Users\YONKYU~1\AppData\Local\Temp\_AIF70B.tmp\x64\acad\acad-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/11/24:10:27:35 Yon Kyu Chung YONKYUCHUNG-PC Install AutoCAD® 2013 Failed Installation aborted, Result=1603
2012/11/24:10:27:37 Yon Kyu Chung YONKYUCHUNG-PC Rollback Autodesk Content Service Language Pack Succeeded
2012/11/24:10:27:39 Yon Kyu Chung YONKYUCHUNG-PC Rollback Autodesk Content Service Succeeded
2012/11/24:10:27:50 Yon Kyu Chung YONKYUCHUNG-PC Rollback Autodesk Material Library 2013 - Low Resolution Succeeded
2012/11/24:10:28:05 Yon Kyu Chung YONKYUCHUNG-PC Rollback Autodesk Material Library 2013 Succeeded
2012/11/24:10:28:06 Yon Kyu Chung YONKYUCHUNG-PC Rollback FaroSDK Succeeded
2012/11/24:10:28:06 Yon Kyu Chung YONKYUCHUNG-PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2012/11/24:10:28:06 Yon Kyu Chung YONKYUCHUNG-PC Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x64) Failed Installation aborted, Result=1619
2012/11/24:10:28:06 Yon Kyu Chung YONKYUCHUNG-PC Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x86) Failed Installation aborted, Result=1619
